Brake pad noise
Old May 15, 2014 | 08:34 AM
PH98I30's Avatar
Brake pad noise
Hi Guys,
98 I30. Car has 132K on the clock. I have had the car 3 years. Going thru the previous owner records I can't find any brake service records. I am getting a faint grinding noise when I stop at lights, so I believe I am due for some new pads. I can't see the pads very well thru the wheel, so I will probably pull the wheel off to get a better look. I would like some recommendations on pads- semi metallic, ceramic, best brands? Thanks all.
Old May 15, 2014 | 08:37 AM
CustomLowz's Avatar
Originally Posted by PH98I30
Hi Guys,
I am a fan of ceramic pads myself. If you are going through the trouble to replace the pads, I would do the brake rotors as well.
Old May 15, 2014 | 08:40 AM
asand1's Avatar
Now that I have my 71"s on, I am sorry I got the cheap Napa semimetalics. They dust like crazy. Get ceramic or high end semimetalics, as i think they dust less.
Old May 15, 2014 | 09:31 AM
PH98I30's Avatar
Thanks for the reply. This site is the best. I was told ceramic is best, so I am leaning that way. Do you suggest having the rotors turned on or off the car?
Old May 15, 2014 | 10:24 AM
CustomLowz's Avatar
Id suggest replacing the rotors. It will cost a few $$ more but you will have brand new instead.
Old May 15, 2014 | 10:30 AM
asand1's Avatar
Turning rotors removes metal and increases chances of warping. With the price of turning rotors, you can get new rotors for not much less.
Old May 15, 2014 | 03:41 PM
PH98I30's Avatar
Excellent idea. Have any recommendations on brands and where to go?
Old May 15, 2014 | 04:15 PM
bumpypickle's Avatar
I have akebonos on the front and a pair of autozone pads on the rear (couldn't return) but they both don't squeal or squeak. I definatley reccomended new rotors. They're really not that expensive.
Old May 15, 2014 | 04:18 PM
Also try doing the fronts yourself. It's actually pretty easy (as long as your calipers aren't frozen like mine were.)
Old May 15, 2014 | 05:09 PM
njmaxseltd's Avatar
If the car needs brakes, the Akebonos pads are excellent. Another excellent pad is the Wagner Therom Quiet. You should replace the rotors and do a proper bedding in procedure for optimal performance and life.
Google brake pad bedding procedure for instructions.
FYI - there really is no such thing as a warped rotor, it's pad material transfer that causes brake judder.
Old May 15, 2014 | 06:29 PM
jholley's Avatar
If you want ceramic with less dust then try autozone's ceramic pads.
Front DG653
Rear DG540
They have a lifetime warranty. Being a well known customer I trade them in for new pads every 6 months with no questions asked.
The autozone duralast gold rotors are also high quality. With over 50,000 miles they are nearly as thick as new.
Old May 15, 2014 | 08:05 PM
Patm-a32's Avatar
I perfer ceramic pads ... And if ur not seeing any records of brake service i would replace the rotors too. When my brakes were grinding it was the pads wearing very unevenly
Old May 16, 2014 | 05:58 AM
Calabar's Avatar
I did my pads and rotors, I bought drilled and slotted rotors and ceramic pads installed myself good chance your caliper piston will freeze up there's a special tool you need for back calipers
Old May 17, 2014 | 01:12 AM
CMax03's Avatar
I'm really impressed with the Powerstop Extreme pads which are a Hybrid formula of ceramic/carbon fiber and man these pads and their Xdrilled/slotted rotors really stop this My 5.5th Gen like crazy!!!!....Gotta upgrade my 4th Gen and 3rd Gen brakes now
Old May 20, 2014 | 05:14 PM
PH98I30's Avatar
Thank you to everyone for your responses. I am going with akebono ultra premium ceramic pads. I will use new Brembo rotors. I will clean them before I install them and check the run out on them just because I don't want any shimmy. I have done my own work for 25 years on Camry's I have owned. I really think this car puts a Camry to shame. It feels sturdier and tighter in the steering. I will be back for more input if I need help but I have done brakes before, but that was about 10 years ago.
Thanks all.
Old May 20, 2014 | 06:00 PM
CS_AR's Avatar
Thanks all.
I use those Akebono pads on my Q45. I have had great results. I don't notice brake dust of any significance. They do a great job of stopping that monster behemoth. At 142,000 miles the rotors have never been turned. I have no a reason to turn the rotors because there is no vibration or grooving. The previous owner (though I've had it 4 years now) kept an eye on pad wear and would proactively replace worn pads before the rotors started taking a hit.
Old May 20, 2014 | 06:08 PM
CS_AR's Avatar
Removed duplicate post.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
