Having trouble with P/S
Old May 28, 2014 | 11:55 PM
hortiz1982's Avatar
Hello all,
I recently rebuilt my p/s pump with an oem kit from LA Nissan. It seems to never run out of air bubbles during the bleeding process as I've sat there turning for hours on end. The pump also whines when I'm running the engine to check for leaks. No leaks btw. Any help is appreciated.
Old May 29, 2014 | 12:16 AM
Fakie J Farkerton's Avatar
Bubbles? Whining? Rebuilt?
Sounds like you may need to check your work.
I've never heard of a rebuild kit for the PS pump, but I've also never looked into it.
That's just a part I would buy new if needed.
Now, alternators or starters seems simple enough, but anything with the word pump..no thanks.
Old May 29, 2014 | 04:32 AM
CS_AR's Avatar
Originally Posted by hortiz1982
Hello all,
Unfortunately I had the same experience with the kit on a Q45 pump that looks like the same pump as the Maxima. Mine had a leak problem also. After a couple of days I said "forget it" and picked up a rebuilt pump from Advance Auto (in store pickup) using a HUGE50 coupon code. Four years later it is still quiet and works fine.
14GmMax
59
Aug 4, 2019 11:26 AM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
