View Poll Results: no start after clutch replacement
new crank and cam sensors
0%
engine harness ohms out good
0%
battery is weak but will start with jump
0%
road test vehicle loses spark
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Starting issue after clutch replacement
Old Jun 2, 2014 | 12:46 PM
twobrosauto's Avatar
after clutch replacement, lost spark intermittently, checked and replaced crank and cam sensors, check continuity between sensors and ecm, all checked out good...after vehicle sits, starts and runs great, road test vehicle, runs rough, bucking as if cat is restricted, shut vehicle off, starts and runs fine...also mass air flow sensor is known good tester, also during clutch swap, cleaned mating surfaces engine to trans for good clean ground, as anyone run into this same issue. im at a lost...
Old Jun 4, 2014 | 07:38 PM
Drag0n97's Avatar
Did u make sure the key was lined up when u put the flywheel back in?
Old Jun 4, 2014 | 09:36 PM
Maxima 97 SE's Avatar
You've did you use oem sensors or aftermarket. If aftermarket, put the oem sensors back in and see if it works better because aftermarket sensor have a hard time communicating with the Ecu and can give false readings.
Old Jun 5, 2014 | 04:37 AM
98maxaholic's Avatar
what about the mating surfaces between the trans and motor? alot of people had luck after sanding the surfaces!
Old Jun 5, 2014 | 06:42 AM
Quickywd01's Avatar
I was going to say the mating surface issue but he obviously can't have that issue right?
Old Jun 5, 2014 | 07:32 AM
OOPS, i over looked where he stated he did the mating surfaces..
kjlouis
Nov 24, 2018 06:09 AM
vingodine
45
May 21, 2016 12:46 PM
maxinout93
Aug 20, 2015 02:17 AM
vanebecker
Aug 17, 2015 08:24 PM
kirkhilles
Aug 8, 2015 10:53 AM
