95 melted headlight
Old Jun 7, 2014 | 09:38 PM
jfactor's Avatar
95 melted headlight
Went to change my oil and noticed my headlight had a hole melted through from the inside. Has anybody else seen this happen with the glass headlights on the 95s?
Old Jun 8, 2014 | 09:12 AM
Amerikaner83's Avatar
standard halogen headlights or pnp HID kit?
Old Jun 8, 2014 | 11:04 AM
max ride 41's Avatar
yeah, you can't melt a glass headlight with a stock bulb. i don't think a hid bulb could melt a glass headlight either. you can melt the bulb socket with high wattage bulbs, i've done that.
Old Jun 9, 2014 | 07:34 AM
jfactor's Avatar
All the lights are stock oem. The headlight bulbs are the same ones that were in the car when I bought it about 5 years ago.
Old Jun 9, 2014 | 07:59 AM
ac max 92's Avatar
Did you buy the car used? Perhaps someone else previously put in a high wattage bulb. Anything above 55w on the halogen bulbs tend to melt the harness. If not you may have a bad connection. Should get it checked so it doesn't start a fire. Maybe check your local scrapyard for a used one. They shouldn't be too pricey
Old Jun 9, 2014 | 12:07 PM
jfactor's Avatar
Yes the car was bought used ac. Already checked bulbs and wiring. There aren't any modifications to any of the lighting. Car has no funky smells, I know what that type of issue would smell like. And I really doubt any issues like what you described could do this:
20140607_121253.jpg?t=1402259183
Old Jun 9, 2014 | 03:08 PM
njmaxseltd's Avatar
That's a rock impact and what you're seeing is the break out from behind.
Old Jun 9, 2014 | 03:37 PM
96i30azn's Avatar
My window has the same type of hole from a bb gun
Old Jun 9, 2014 | 05:42 PM
ac max 92's Avatar
Does appear to be a hole from a pellet gun or something?
Old Jun 9, 2014 | 06:02 PM
asand1's Avatar
+4
Rock. I had the same on mine. The chip should be floating around in there still.
Old Jun 10, 2014 | 06:06 AM
jfactor's Avatar
A rock break out wouldn't melt glass. I did examine the headlight closer yesterday evening and saw small glass chunks and shavings inside. Some a hole clearly drilled my darn headlight. Starting the hole broke the glass at the back and heat from drilling melted the rough area left by the broken off parts. Seems to be the most plausible explanation.
Old Jun 10, 2014 | 06:21 AM
shiloh51933's Avatar
Originally Posted by njmaxseltd
that's a rock impact and what you're seeing is the break out from behind.
+1
When my euro clear glass lens got hit by a rock it looked exactly like yours...I doubt ur ride was vandalized. You can fill it with clear epoxy for now until you get a new lens.
Old Jun 10, 2014 | 12:06 PM
jfactor's Avatar
How would you explain the almost perfect circle hole with what appears to be burn marks around the circumference of the hole. And I'd think the area on the outside surrounding the hole would show signs of impact. Far as a new lense goes I'm not replacing anything, trying not to buy anything I don't have to and just put that cash towards something newer.
Old Jun 10, 2014 | 03:33 PM
Classic evidence of alien probing with unclean instrumentation
Old Jun 10, 2014 | 06:37 PM
'95-'96 headlights suck anyway. Time to upgrade
Old Jun 11, 2014 | 02:58 PM
96i30azn's Avatar
How would you explain it's NOT perfect? Poor evidence for one hypothesis is NOT evidence for another.
Old Jun 11, 2014 | 03:32 PM
TexasTex's Avatar
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
Noela
Sep 26, 2015 08:22 AM
