Low Compression while engine is running
Old Jul 12, 2014 | 05:03 PM
man_flannel's Avatar
I have a 1995 Maxima and have a misfire on the number 5 cylinder (back driver side). I know the coil is good because I swapped it with another cylinder and still had a misfire on number 5. Nearly positive that the fuel injector is good because it was changed less than a year ago. Plug is good also. So fuel and spark is good.
That leaves compression. If I disconnect all the coils and just turn the engine over with the starter, number 5 cylinder has over 120 psi, which should be fine. However, If I reconnect all of the coils and have the engine running on the other 5 cylinders, number 5 cylinder only has 30 psi, which would cause the misfire.
I'm thinking I have a valve problem, maybe a weak spring or a sticky valve or something. If it was bad piston rings I wouldn't be getting the 120 psi when just cranking it with the starter.
Any advice/thoughts is greatly appreciated. Thanks.
Old Jul 12, 2014 | 05:07 PM
Chad_m's Avatar
Have you squirted a little oil into the spark plug hole and then rechecked it?
Old Jul 12, 2014 | 05:12 PM
No but that does sound like a good idea. Thanks for the input
vybz05
Dec 10, 2015 07:38 PM
schmellyfart
Sep 25, 2015 04:47 PM
Slamrod
Sep 3, 2015 07:38 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
