trouble at start up
Old Jan 22, 2002 | 09:34 AM
paul-e's Avatar
trouble at start up
i have been getting wired noises at start up every morning for a while and today i went to start it up and it was going so i tried again and then i gave some gas and it finally started.......any ideas?
Old Jan 22, 2002 | 09:51 AM
pocketrocket's Avatar
Re: trouble at start up
weird noises .. very vague.
Dunno if it's the starter going out?
(donkey whine sound for about 1/2 second after you turn the key because the starter keeps going even though you've released the key)
or if you've got other problems? Might help if you describe the problem a bit more in detail.
Old Jan 22, 2002 | 09:55 AM
pmg's Avatar
pmg
Hey, my starter does the thing where it keeps going for 1/2 second after I've released the key (when it's cold out). It's been like this for 2 years. Should I replace the starter before it goes or leave it?
-Jeremy
Old Jan 22, 2002 | 10:20 AM
njmaxseltd's Avatar
-Jeremy
www.motorvate.com has instructions on how to repair this problem yourself for about 5 bucks! You have to remove your starter, claan and re-grease the gears inside.
Old Jan 22, 2002 | 10:41 AM
98sterlingmist's Avatar
My starter made that noise, usually only in cold weather, and I finally had to have it replaced.
The Other problem I have had is that the car would start and just die like it was not getting fuel or air. I cleaned the throttle body and that made a world of difference in performance and have not had the starting problem again.
bryants95max
Oct 2, 2015 12:52 PM
QueensMAX
Sep 15, 2015 04:14 AM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
