02 sensor problems
Old Aug 10, 2014 | 06:27 PM
max-nutcase's Avatar
02 sensor problems
I had an ecu code of 0413 which is left precat, anyway i put a new ntk sensor in it today..then after driving it for awhile the 0413 came back with a 1001 code ,which possible causes are harness or connectors, (the front heated oxygen sensor circuit is open or shorted,front heated oxygen sensor heater
has anyone had this code and found a remedy? all help appreciated!!
thanks in advance!!!!:confused :
im begining to think the 02 i changed wasnt bad cuz it had only 3000 miles on it...what should i do??????
Old Aug 11, 2014 | 09:02 AM
JvG's Avatar
JvG
Did you use an oxy sensor with a connector at the end of the wire (plug and play) or did you need to attach the old connector on to the new sensor?
If you attached your old plug to the new sensor it is possible that you might have a disconnected wire or a short.
Old Aug 11, 2014 | 09:08 AM
Quickywd01's Avatar
http://www.ebay.com/itm/NEW-DENSO-OX...3D291189229067
Old Aug 11, 2014 | 09:52 AM
thats the one i got..but it was a bulk one..not in a retail box..but did have a plug on it...but the old one was only 4k miles old and wasnt giving me the 1001 code.just the 0413 code...now im stumped..maybe it was dropped in transit or something ?
Old Aug 11, 2014 | 10:05 AM
max ride 41's Avatar
i replaced my bank one sensor one p0130 2 times and the code keeps coming back. i think i might have an exhaust leak, if not i'm going to be confused as hell as to what the problem is.
Old Aug 11, 2014 | 11:04 AM
cashoit's Avatar
so who can confirm that the NTK's work????
I have heard only original OEM oxygen sensors from the dealer actually work.
Old Aug 11, 2014 | 11:12 AM
Fakie J Farkerton's Avatar
Originally Posted by cashoit
so who can confirm that the NTK's work???? I have heard only original OEM oxygen sensors from the dealer actually work.
Seriously?
NTK's might even be OEM without the Nissan stamp.
Old Aug 11, 2014 | 11:49 AM
Originally Posted by Fakie J Farkerton
Seriously?
they are, i asked a local nissan dealer
Old Aug 12, 2014 | 08:20 AM
Ya come to think of it, exaust leak is probably my problem also...i dont think the exhaust has been touched since new from the back of the cat back..so havin a leak after 16 yrs near the 02 sensor wouldnt be to unlikely
but so far i reset the ecu and no code yet..been about 200 miles...hope its gone for good!
Old Aug 12, 2014 | 08:50 AM
Quickywd01's Avatar
I just bought two of those for my beater. Going to put then in after I spray ceramic on the new ws y-pipe.
Old Aug 12, 2014 | 05:54 PM
warpspeed, mmmhmmmm
Old Aug 14, 2014 | 08:59 AM
Im hopin for some help...after i reset the code again ,after i installed a new ntk 02 sensor the 0110 code came back....
now i dont see or hear an exaust leak up near the 02 ..but how close to the 02 would an exaust leak have to be if that is wats causin the 0110 code?...i just hate seein the damn cel on..and dont see an exaust leak near the 02...wtf?
Old Aug 14, 2014 | 09:13 AM
surban1's Avatar
what code are you actually getting; in one post you mention 1001 but in another post you say 0110?? which is it? and are these the p codes or from the ecm flashes?
if you are getting the 1001 (aka p0155) code and have already changed to a ntk o2 sensor, check the harness/connector to the sensor, and then check the component itself if the harness checked out ok). the fsm has the procedure in the EC section.
Old Aug 14, 2014 | 11:19 AM
Sorry, im getting 1001 by the ecu.....ive been lookin at the fsm ...but unfortunately im not familiar with using a multimeter...i guess its time i learn...
...but the funny thing is ,the one i changed had only 4k miles on it (ntk also)and I was only getting the 0413 ecu code..since i changed it im gettin both ecu codes..0413/1001? i reset the ecu 3 times and witin 150 miles they come back,i think the the one i changed is fine ,glad i saved it..as far as using a multimeter goes..im not sure what infinite and all the gobbly goo terms mean..i can test volts and thats about it...i guess im f%$#ed! til i learn how a multimeter is used!
i forgot to mention that i cleaned the maf with the right cleaner..i seen someting in the fsm that says to unplug the maf then clear the codes again??...man what a learning experience!!
Im thinking that maybe the sensor got dropped in transit to my house ...to just have 0413 with the old sensor in, to havin 1001 and 0413 after the new ones in..maybe the sensor is sheeet??
bbsitum
Sep 6, 2019 07:31 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 23, 2015 08:46 PM
