can i use my starter to loosen crank pulley bolt while everything is taken apart?
Old Aug 11, 2014 | 08:17 PM
bjaffry's Avatar
Hey im in the process of getting behind my timing cover and I need to get my crank pulley off. I have the oil drained and both valve covers off..is it cool if I lock a breaker bar on the pulley and tap the starter to break it loose?
Old Aug 11, 2014 | 08:33 PM
chrome91's Avatar
personally wouldnt do it. valve covers off is fine but with the oil drained i wouldnt
Old Aug 11, 2014 | 08:43 PM
bjaffry's Avatar
any recommendations to getting it off? I read you can jam the flywheel from beneath the tranny..but it looks like you have to take the cross-member off..or jam it from where the starter goes in. Any other quick way of taking it off without removing any parts?
thanks
Old Aug 11, 2014 | 09:00 PM
chrome91's Avatar
i usually use an air gun, once the bolts off i use a pulley puller to get the pulley off. but most likely you dont have an air compressor etc at your disposal
Old Aug 12, 2014 | 03:02 AM
CS_AR's Avatar
If you want the truth, I have used that approach two times on VQ30DE and once on my VH45DE -- so basically every time I need to remove the crankshaft pulley. I have a long breaker bar for that purpose. I let the bar have about 1" of free travel before it makes contact to break the bolt free. The first time I tried to break the bolt loose, I did not allow any free travel and the starter just locked up without turning the crankshaft. I do not let the bar hit another component like the guy video. I have the spark plugs removed and the fuel pump disconnected before attempting this operation also.
https://www.youtube.com/watch?v=7G-adEVjfWI
If you have a 99 model, be sure to get in and "close the door" before you start tapping the starter for a maintenance operation. The 99 models have an immobilizer that can be tripped if you unsuccessfully try to start the vehicle with the driver's door open.
Old Aug 12, 2014 | 03:49 AM
dwapenyi's Avatar
Since the over head cams are fully exposed, how about pouring oil over the cams and into the spark plug holes, let soak a few moments, then tap the starter?
Just an idea
Old Aug 12, 2014 | 06:45 AM
CS_AR's Avatar
Just in case you haven't already seen the following thread, you might want to give it a look. I learned a couple of things the hard way in that exercise..
https://maxima.org/forums/4th-genera...moval-tip.html
Old Aug 12, 2014 | 08:03 AM
CMax03's Avatar
Bumping the starter won't hurt a thing! Just a couple of bumps and it should break loose!
Old Aug 12, 2014 | 09:28 AM
02FrostWhite6spd's Avatar
I too was stuck with the crank pulley bolt for like over a week then I Thankfully found a post from Aaron92se on his VQ35de 3rd gen build.
heres the link
https://maxima.org/forums/all-motor/...-thread-3.html
page 3, post #120
wrap the belt around the pulley then around 1 of the transmission bolts and turn the crank pulley counter -clockwise until the belt overlaps itself then Voila!
it helps to have 2 people but i was able to do it by myself.
1 person the turn the crank counter-clockwise and 1 person to guide the belt to make sure it overlaps and gets real tight.
breaker bar with a 4 foot pipe attached helps a ton also.
Old Aug 12, 2014 | 09:37 AM
metalgod3082's Avatar
I've bumped the starter several times with everything removed with no issues whatsover and works like a charm. There is enough residual oil on everything even after it is drained that it won't hurt anything. Just don't keep cranking and cranking, just a quick blip and it should come right off
Old Aug 13, 2014 | 05:41 PM
mikeyen's Avatar
I concur. You won't be on the starter for more than 1 second. That's just not enough time to hurt anything.
Old Aug 13, 2014 | 06:44 PM
asand1's Avatar
And it wouldn't be enough time to pump any oil anyways. The engine won't know the difference.
litch
123
Jan 4, 2024 07:01 PM
TKHanson
Nov 24, 2018 01:39 AM
RealityCheck
Oct 2, 2015 06:34 PM
zmcneely13
Sep 26, 2015 02:26 PM
