Missing part under throttle body?
Old Aug 24, 2014 | 09:47 AM
edwardh1's Avatar
These two pix are a 1999 max v6 under the throttle body. A small vacuum line 1 inch long hangs down- is a part missing or should this line be capped or connected to something??
Old Aug 24, 2014 | 09:49 AM
edwardh1's Avatar
sorry I cant seem to post,
its where the air intake bellows is connected to the throttle body , and then on the bottom (down side, looks like 1/4 inch rubber vac hose hanging down
Old Aug 24, 2014 | 10:02 AM
BigLou55's Avatar
That's not a vacuum line its a coolant line and you should see the same thing right under the throttle cable part of of the throttle body (TB). You should see another connection point on the coolant lines very close to the TB. The previous owner may have performed the TB coolant bypass, if so just cap them to keep debris out for good measure.
Old Aug 24, 2014 | 10:20 AM
edwardh1's Avatar
if anyone could post the two pix I would I would appreciate it if someone could do it ( I dont post pix much)
send me an e mail address by pm and I will e mail the two pix??
Old Aug 24, 2014 | 10:22 AM
edwardh1's Avatar
Thanks, its a really small hose, not the size of the other hoses that look like coolant.
no previous owner, factory stock
could I email you the pix?
Old Aug 24, 2014 | 08:50 PM
RA030726's Avatar
I'm nutty for Nissans
Has never meant so much. I'd like to help but there are far too many hoses to guess.
Old Aug 25, 2014 | 08:51 AM
edwardh1's Avatar
its just one hose under the intake of the throttle body, hose in 1 inch long points straight down, and is open on the bottom
Old Aug 25, 2014 | 01:04 PM
PH98I30's Avatar
It sounds like the transmission breather hose. Do a search on here. There are pictures of it. I'm guessing that is it but a picture will tell.
Old Aug 26, 2014 | 10:40 AM
metalgod3082's Avatar
I know what you are talking about and mine has the same thing. It's neither a coolant or vacuum hose. Mine is actually a 1 inch long rubber cap or something. I thought I was missing a hose there as well so I took that rubber piece off and it is solid in the middle and nothing can pass through, not sure what it is there for but seems to be some sort of cap.
Mine is a 99 as well btw so maybe it is only a 99 thing?
It's the little black hose looking thing sticking straight down
Old Aug 29, 2014 | 09:17 PM
^Is that what you were talking about OP?
Old Aug 31, 2014 | 05:35 PM
edwardh1's Avatar
yes yes thanks so much
vingodine
45
May 21, 2016 12:46 PM
iflexsteel
Sep 15, 2015 03:37 AM
homewrecker
Aug 24, 2015 08:56 PM
Samedi
Aug 13, 2015 04:05 PM
