Low Pressure Power Steering Hose Size(s)
Old Sep 6, 2014 | 08:09 PM
95naSTA's Avatar
Are they 3/8" or 5/8" or either depending on the hose location?
I'm looking for the sizes for all sections of all the low pressure hoses.
TIA
Old Sep 12, 2014 | 07:08 AM
95naSTA's Avatar
bump
Old Sep 12, 2014 | 08:35 AM
arcticracer's Avatar
3/8
Old Oct 3, 2014 | 09:58 PM
95naSTA's Avatar
Started the job and there are the following
3/8" lines:
From body hard line to rack low pressure port (along the firewall)
Cooler to reservoir
Cooler to body hard line
5/8" line:
Reservoir to pump
To replace all the low pressure rubber lines you'll need about 10 feet of 3/8" and 2 feet of 5/8".
Old Oct 20, 2024 | 05:07 AM
AAB30's Avatar
Accessing power steering hoses
3/8" lines:
Cooler to reservoir
5/8" line:
Reservoir to pump
Hey guys. Can I reach all if not most of the hoses by removing the right wheel along with the wheel lining? I got steering fluid all over the floor here my car is 216k miles 2017 sv. Trying to fix this problem before work in the am. Thank you
Old Oct 28, 2024 | 06:00 AM
95maxrider's Avatar
Lightly modded
You should post in the 7th gen forum, this is the 4th gen forum.
I'm guessing you can get to most of them that way, but some of the lines going to the PS pump are on the back of the engine, so you'll need to crawl under the engine to get to them.
iflexsteel
Sep 15, 2015 03:37 AM
MichMaxFan
Garage and Workshop
Sep 2, 2015 06:35 AM
hydriplex
Aug 28, 2015 02:13 PM
Mrbizness1
Aug 18, 2015 08:43 PM
scarletsosa
Aug 17, 2015 09:09 PM
