Replacing hard brake lines
Old Sep 9, 2014 | 10:36 AM
barnone's Avatar
So, i was poking around underneath and noticed my hard lines to the rear are in real bad shape, ie. rusted out and leaking. The whole section where they run parallel to the fuel lines up to the LCM bushing is a disaster so I thought about replacing the whole damned thing rather than just try to splice near the firewall.
Each rear line comes in 2 sections that couple at the firewall. Is that coupler necessary? Does it do anything other than join the lines together? Can I just run single lines straight to the master and bypass that thing to make life easier?
Old Sep 9, 2014 | 10:59 AM
njmaxseltd's Avatar
You're still going to have 2 lines to join. I'd stick to the factory layout.
Do not splice brake lines, never use compression fittings.
Go from a threaded port to a threaded port.
Old Sep 9, 2014 | 11:13 AM
barnone's Avatar
That's the thing, I'd rather not go to that connector if it's not absolutely necessary, since it's a royal PITA to get to. I'd just go caliper to master - it would make routing a hell of a lot easier. The real question is whether that connector serves a purpose other than connecting the 2 sections of each rear line.
Thanks!
Old Sep 9, 2014 | 07:59 PM
RA030726's Avatar
I'm nutty for Nissans
Sounds like the proportioning valve which you need.
rbuswell
Nov 17, 2016 04:54 AM
vingodine
45
May 21, 2016 12:46 PM
seesole
Aug 26, 2015 11:22 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
