lower ball joint touching drive axle
Old Sep 12, 2014 | 10:35 PM
LuminousX's Avatar
what would cause my lower ball joint to touch my drive axle? on the passenger side
Old Sep 13, 2014 | 12:23 AM
Fakie J Farkerton's Avatar
Bent knuckle.
Old Sep 13, 2014 | 12:41 AM
LuminousX's Avatar
what's this *knuckle* and where is it?
Old Sep 13, 2014 | 12:45 AM
The knuckle is what the ball joint bolts to.
I haven't heard of this problem, so I'm just making a guess.
The balljoint shouldn't be able to thread enough to touch the axle..that's the only thing I can picture being the problem at the moment.
I'm very curious to see what the answer ends up being here.
Old Sep 13, 2014 | 12:58 AM
LuminousX's Avatar
the thing that holds the brake disc, and the whole 9 yard, that thing is way to thick for anything to bend it, but I'm pretty sure if it was bend to that degree I would have notice it, I will however take a better look to see if it's bend those, and if so I'm going hammer
Old Sep 13, 2014 | 08:30 AM
arcticracer's Avatar
Bent strut as they bend fairly easily just above the lower mount or control arm.
Old Sep 13, 2014 | 01:28 PM
That does make more sense.
Old Sep 14, 2014 | 12:26 AM
CMax03's Avatar
Does the balljoint have it's Circlip/snapring installed? The only thing going on here is the lower balljoint in moving upward out of the LCA cause either the snapring wasn't installed properly or wasn't installed at all!
Old Sep 14, 2014 | 04:08 AM
LuminousX's Avatar
I thought that was the case too, but when I put a new one on it the same thing happen, I had to cut the bolt, the ring was on the old out, and is on the new one, plus the ball joint can't get pushed up to the point where it's out of place because it's installed in an upward fashion
maxocar
Aug 21, 2015 12:57 AM
jhontelj
Aug 17, 2015 04:07 AM
soon2ownmax
Aug 13, 2015 02:19 PM
Flores94
Aug 11, 2015 12:53 PM
classymax420
Aug 6, 2015 06:35 PM
