CEL turned off on its own, codes still saved?
Old Nov 15, 2014 | 10:26 AM
619MAX's Avatar
96 Maxima, had cel but it turned off before I could check it. Any way the computer stored it so I can still retrieve it?
Searched maxima cel stored code to no avail, thanks
Old Nov 15, 2014 | 10:43 AM
njmaxseltd's Avatar
If the error is intermittent, then the error will clear itself when "X" number of error free drive cycles have been completed. A professional grade scanner may still see a pending code. I have a rear O2 that sets a code about once a month and clears within a week.
Old Nov 15, 2014 | 10:55 AM
619MAX's Avatar
That's about the amount of time it turned off in...I also noticed it had a funny o2 sensor reading when I hooked it up for diagnostics a couple months ago so I'm guessing o2. Car has 87,xxx miles and I hear they're due every 100k-ish?
Old Nov 15, 2014 | 11:36 AM
CS_AR's Avatar
That's what I've read over the years. I've read the rule of thumb is:
OBDI cars (pre-4th gen models) - 60,000 miles
OBDII cars - 100,000 miles.
I've replaced O2 sensors on three 4th gens so far. Usually I buy a 4th gen with 150,000 miles or more that still has the originals. I've noticed an improvement in low end pep and maybe a mile or two MPG improvement after I install new ones.
I've only used NTK (NGK) brand O2 sensors.. Not saying others are bad -- just no experience with anything else.. I think guys find some deals for O2 sensors on eBay. I've bought some there that turned out good..
Here's a PhotoBucket story board (new feature) where I changed O2 sensors on my first 4th gen (95 model).
As you can see I had some rust issues to deal with on that car.
http://s286.photobucket.com/user/Rid..._Sensors/story
Old Nov 15, 2014 | 10:14 PM
Finkle's Avatar
They might be stored under historic codes. I use the torque app that has a option to pull historic codes. I don't know how long a code will sit there before being erased completely.
Old Nov 15, 2014 | 10:22 PM
JoshG's Avatar
or maybe ur CEL light bulb went out? does it turn on ignition mode?
sctludwig
Sep 1, 2022 01:32 PM
bryants95max
Oct 2, 2015 12:52 PM
rnb754
Sep 14, 2015 11:39 PM
LtLeary
Sep 14, 2015 12:33 PM
