Right headlight lowbeam stays on
Old Nov 19, 2014 | 12:22 AM
ToniK's Avatar
Hello,
my 1999 3.0 Maximas right headlight stays on all the time. Left goes off normally. I have to take the fuse off. I tried to find relay for the right low beam, but cannot find it. Any ideas whats going on? Is the problem in the steering wheel light switch?
Thanks for the help!
Toni
Old Nov 19, 2014 | 12:51 AM
DennisMik's Avatar
There are not any relays used with the headlights.
When I hear of screwy things with the headlights like this, my first question is: do you have a Canadian Maxima. Canada requires daytime running lights and the control module that Nissan uses for that has serious quality problems. 99% of the time the DTRL (Day Time Running Light) module suffers from bad solder connections. This is easily fixed with a hot soldering iron.
On a U.S. Maxima, this problem most likely is the headlight switch.
Old Nov 19, 2014 | 01:02 AM
ToniK's Avatar
Hello,
i have european model, i dont think i have any daytime lights. Lights go automatically on when starting the car. Maybe the problem is in the switch then.
Thanks,
Toni
Old Nov 19, 2014 | 02:31 AM
DennisMik's Avatar
I do not have a lot of knowledge on the European Maxima. Is this the Maxima QX?
If the lights come on in the daytime, you may have the daytime running lights.
In Canada, the daytime running lights use the headlight high beams, but the lamp is given half voltage so it is not at full brightness.
Is the headlight switch in the off position when the lights come on? This would mean daytime running lights.
Old Nov 19, 2014 | 02:44 PM
andoneA32's Avatar
Just unplug the DRL module. Its beside the coolant reservoir. Unless its worth it to you to get it fixed.
Old Nov 19, 2014 | 10:10 PM
ToniK's Avatar
Car is Maxima qx, there isnt any daytime running lights module in my car. So i still think its the switch which cause the problem. Its the normal low beam what goes on when i start the motor and the switch is 0 position. When i turn the switch on its the same low beam whats on. Only difference is that i can use high beams when switch is on position.
Old Nov 19, 2014 | 10:26 PM
max ride 41's Avatar
are you folks with qx models allowed to to custom retrofits with hids in them?? i would seriously hate to only have stock lights in the max.
Miket2006
Mar 1, 2021 03:55 AM
doctorpullit
Oct 28, 2019 10:58 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
leatherneck
Sep 30, 2015 09:16 PM
Noela
Sep 26, 2015 08:22 AM
