Free maxima I got needs some work done.
Old Feb 11, 2015 | 10:57 AM
Striker2237's Avatar
So I picked up a maxima for free but it needs some parts replaced. Does anyone here know the preferred brand and type of spark plugs the 3.0 likes? Gap? Also I need new axles, whats a good brand? The plenum seems to be the source of the huge vacuum leak and I was going to go with a victor reniz gasket set, same company for the valve covers. Also where the heck can you buy upper control arms for this thing? I can only seem to find lowers online.....
Old Feb 11, 2015 | 11:04 AM
LuminousX's Avatar
it doesn't have an upper control arm that's why
Wait what? How the heck is the wheel controlled then? Is it a strut or something?
Old Feb 11, 2015 | 11:13 AM
matts95max's Avatar
I would recommend taking a good look at your car, maybe even have a friend or family member who knows a bit about them come out and look it over with you. They can tell you all about what is where and answer your questions. I would start with that before doing anything.
Old Feb 11, 2015 | 11:59 AM
LuminousX's Avatar
did someone tell you the car needed a "Upper Control Arm" as far as I know the suspension is consist of lower control arm, lower balljoint, inner, and outter tie rod, swaybar link
Old Feb 11, 2015 | 12:22 PM
Well that's my bad then, I normally deal with trucks and SUVs. I forgot some cars don't use two arms, reason for this seemingly stupid question is because I am in Ohio and the car is in Florida. I'm trying to figure out what parts I need to bring with me to get this thing ready to come home with me. Old owner had his dealership make a list of everything they thought needed fixed (just said control arms so I assumed all 4, even though now that I looked online this thing uses struts) so I am currently going off that. FYI I am a mechanic lol!
Old Feb 11, 2015 | 12:28 PM
LuminousX's Avatar
Struts aren't gonna stop the car from driving if you want to be on the safe side then get this thing here, start from the control arm, and work your way to the outter tie rod end last, best way to go about it
Old Feb 11, 2015 | 12:33 PM
Yeah I ordered everything there plus a valve and plenum gasket set, also a pair of axles and new window motors. I was just confused because I normally see a separate shock and upper control arm instead of just a strut assembly. Btw do you happen to know what spark plugs this engine likes?
Old Feb 11, 2015 | 01:24 PM
tosheto's Avatar
Ngk
Old Feb 11, 2015 | 01:49 PM
Originally Posted by tosheto
Ngk
Platinum?
Old Feb 11, 2015 | 03:05 PM
LuminousX's Avatar
Original is fine, but if you have the money then go for it, platinum just gives you a longer drive before you have to change them
Old Feb 11, 2015 | 03:48 PM
asand1's Avatar
Coppers perform best, plats perform longer.
Sent from my XT1060 using Maxima
Old Feb 11, 2015 | 04:01 PM
Old Feb 11, 2015 | 04:29 PM
Is there anything other than the usual full fluid flushes, oil, plugs, filters that I should probably do to this car?
Old Feb 11, 2015 | 04:36 PM
vqmaxman's Avatar
This car might need all kinds of flushes, but how many miles you have on this car. The carfax and maintence records do you have any on this car.
Old Feb 11, 2015 | 04:41 PM
vqmaxman's Avatar
I would check on tranny fluid and brake fluid and power steering fluids, coolant and engine oil. I would check belts hoses and all the other things you have stated with the org members and whatever they have stated too.
Old Feb 11, 2015 | 05:17 PM
82k miles, owned by family members so I know its well taken care of.
Old Feb 12, 2015 | 01:01 PM
CMax03's Avatar
Yeah, Family member don't destroy cars....They just drive them down into the ground! Buy a Haynes repair manual...so you can learn as you own, how to maintain a car....rockauto.com or partsgeek.com is an awesome parts source for these cars....
Old Feb 12, 2015 | 05:49 PM
My family is OCD about keeping their cars in good shape, at least appearance wise. I use rock auto for most of my parts, I also have all-data so I don't normally buy paper manuals. Thanks for the pointers though man!
Greenmaxspeed
Aug 8, 2015 12:39 PM
kirkhilles
Aug 8, 2015 10:53 AM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
kenc15
Aug 5, 2015 08:29 AM
