O2 sensor and knock sensor
Old Jan 24, 2002 | 05:22 PM
sarmast's Avatar
Hi,
I was hoping someone could tell me how hard is it to replace the Front Left Heated O2 Sensor and the Knock Sensor in a 97 Max?
I used the ECU decoder at VBmaxima and those are the codes I keep getting after driving it long distances (but only on the return trip, weird). Any help at all will be appreciated, I do not yet have a Haynes or Chiltons, but will be getting one shortly.
Thanks again
Sean
Old Jan 24, 2002 | 06:24 PM
Pappa Grande's Avatar
Re: O2 sensor and knock sensor
Just out of curiousity what type of gas do you use 91+?
Old Jan 24, 2002 | 07:24 PM
sarmast's Avatar
Re: Re: O2 sensor and knock sensor
I almost always use 91+ octane, sometimes I go cheap but it will do it even if I have driven with several 91+ tanks in a row. It only does it on highway driving, never in the city
Old Jan 24, 2002 | 07:26 PM
nigelcmf's Avatar
Not sure about the knock sensor. The O2 sensors are easy to replace. If I remember correctly though, the front one is harder than the rear because of all the precat stuff and support beams. I recommend a short monkey wrench for the front one. Regular wrenches are too long.
Old Jan 24, 2002 | 07:38 PM
clee130's Avatar
The knock sensor is hard to get unless you got fingers like Gumby.
onefastmax's Avatar
The knock sensor is easy to replace. Its on top of the block right under the intake manifold. You can see it from the drivers side. I believe its held on with one 10mm bolt.
Old Jan 24, 2002 | 07:41 PM
Sprint's Avatar
Originally posted by sarmast
Hi,
Thanks again
Sean
the O2 sensor codes off sets the knock sensor code.. replace the O2 sensor.. reset it.. adn the knock sensor code will disappear.. i have seen it too many times
Old Jan 24, 2002 | 07:49 PM
onefastmax's Avatar
Mine is throught the knock and EGR valve right now. Problem is I can't find the EGR problem to fix it. A new EGR didn't help. Any Ideas?
Old Jan 24, 2002 | 07:54 PM
Sprint's Avatar
i thought i told you what to do?
Old Jan 24, 2002 | 07:55 PM
sarmast's Avatar
Does anyone know what a new O2 sensor goes for $$-wise??
Old Jan 24, 2002 | 08:05 PM
Sprint's Avatar
$130 - $180
Old Jan 24, 2002 | 08:07 PM
ejj's Avatar
ejj
http://www.courtesyparts.com/A32_O2-sensors.html
$117.09 minus a 25% discount if you mention the .org.
Old Jan 24, 2002 | 08:14 PM
sarmast's Avatar
What does the "Heated" part front left heated O2 sensor mean?
Old Jan 24, 2002 | 08:18 PM
ejj's Avatar
ejj
For an O2 sensor to get a proper reading, it must first obtain a particular temperature. They heat themselves to that temperature.
Old Jan 25, 2002 | 07:01 AM
Ends up being around $103, but that doesn't include shipping. I almost bought one, except that after switching to 93 octane my CEL indicating both o2 and KS hasn't come back on. If it does I'll be replacing mine as well. I have an unsupported hunch that for 95-96s switching gas will do the trick when you get the CEL for both o2 and KS...
Old Jan 25, 2002 | 09:30 AM
onefastmax's Avatar
My hook up at nissan sais the knock sensor goes out all the time. $165 a pop.
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
