can i use a california cat on my fed 95 max?
Old Feb 28, 2015 | 09:36 AM
max ride 41's Avatar
reason i ask is i've heard the california cats are made with better metal and will last longer than the crap aftermarket cats i have put 2 of on in a little over 2 years. luckily i just passed emissions and it's not a rush item but i don't want my exhaust getting clogged as i have a new cattback. links or someone with a rust free cat off another 95 would be appreciated. what brands are good, i heard bosal and ap, what else?
Old Feb 28, 2015 | 01:25 PM
I have a Bosal. Fit was perfect but if I decide to change it out, I'm going with a resonated test pipe.
Old Feb 28, 2015 | 01:34 PM
Derpington's Avatar
^+1 for Bosal. Install was easy and I've been running issue free with it for a year or so now. Not a bad price either.
Old Feb 28, 2015 | 01:35 PM
I could be wrong here and my memory is a bit fuzzy on this, but isn't there an O2 sensor in your cat? Whereas the 97-99 Maximas, the O2 sensor was in the B-pipe just behind the cat.
Old Feb 28, 2015 | 01:55 PM
Derpington's Avatar
^ You are correct about the O2 sensor in the 95 Fed Spec, not sure about the 97-99 B pipe O2 sensor
Old Feb 28, 2015 | 04:38 PM
there in lye's my problem, 95 max has the hole for the 02 and finding a used one is near impossible. i might go with a bosal but no need at this time. still working for now.
Old Mar 1, 2015 | 09:41 AM
CS_AR's Avatar
Here's a picture of a 99 model B-pipe and sensor. For some reason I couldn't get my phone in focus for that pic..
Funny I don't remember the O2 sensor location on my 95 model but I did change it at some point. I tucked the cable up inside the cabin opening to remove any extra length.
Old Mar 1, 2015 | 09:47 AM
where you have that sensor plugged in is my flex section of the y-pipe on my 95. not do-able for me, thought about a test pipe with a hole in it, would that work?
Old Mar 1, 2015 | 09:56 AM
CS_AR's Avatar
Let's wait to see if TD from NJ will drop in tomorrow morning with some advice. Today I can't remember how a 95 looks to know what all would be involved.
Old Mar 1, 2015 | 10:45 AM
a 95 has a hole in the cat for the sensor where as the 96-99 deleted that.
Old Mar 1, 2015 | 01:15 PM
RA030726's Avatar
I'm nutty for Nissans
95-96 exhausts all have the same setup and dimensions. There might be different part numbers according to the dealer. As long as you get a cat with a bung, you'll be good to go.
I had back luck with a Carsound cat. After the insides disintegrated, I ended up running a B13 cat (200k) and now an A33 cat. You are right OEM cats are better.
captchaos
Mar 15, 2016 12:18 PM
16_SR
Sep 9, 2015 07:14 PM
Maxboy23
Sep 4, 2015 06:04 PM
Samedi
Sep 3, 2015 01:07 PM
Justin Kroll
Sep 2, 2015 11:06 AM
