I have a egr EGR ??
Old 03-28-2015, 09:25 PM
maximaham's Avatar
I have a egr EGR ??
Can the egr valve be serviced/cleaned i asking because a have cleaned the tube and just want to do some preventive maintenance.
I am sure it has some carbon build up.
I thought there was a write up but that was for cleaning the egr tube.
maximaham is offline
Old 03-29-2015, 11:24 AM
theWalkinator's Avatar
Yes you can clean egr valve assuming you can take it out, I tried, but I wasn't able to loosen the big nut so I gave up, on thing you can try, start engine, put you right hand under egr vale and left hand pulling throttle cable or throttle pulley to ramp up engine rpm, if you feel egr valve is pumping the it is good.
theWalkinator is offline
Old 03-29-2015, 02:45 PM
Black Lion
maxprivate's Avatar
Ifs its never been done before I would just replace the ERG valve while you're in there cleaning the guide tube. Thats what I did with mine.
There is a writeup somewhere, try VQpower.com
maxprivate is offline
Old 03-30-2015, 04:46 AM
maximaham's Avatar
Is it okay to use after market or oem only
shilov
02-19-2024 09:40 PM
KabirUTA13
19
10-17-2015 02:15 AM
maxima297
09-24-2015 10:31 AM
JoshG
51
09-21-2015 10:41 PM
bumpypickle
09-19-2015 01:07 AM
Quick Reply: I have a egr EGR ??
