stumped. stalls. Doesent stall. idk
Old Apr 4, 2015 | 05:58 PM
kjlouis's Avatar
Before.:cold start. I start car it ran fine till it idles down then it stalls it takes a few seconds but it eventually dies. obd2 says bad cam sensor, both crank sensors, knock sensor, and of sensor.
I replace both crank sensors and cam sensor. replaced an injector today, #3 cylnder, (ohm resistance on bad one was 113.9)
after: cold start, miss for a few seconds then runs fune, idle down and stall after it warms up. I drove it 30 miles on Highway and it didn't stall any more after I got on Highway it wouldn't rev over 3.5k. it misses like its hitting a cut off.
from 65 clutch in coast down to 45 when down shift to 4th release clutch mass misfire. Clutch in, rev, engage clutch, all good.
Last edited by kjlouis; Apr 4, 2015 at 06:06 PM. Reason: phone died switched to pc
Old Apr 4, 2015 | 06:10 PM
kjlouis's Avatar
additional info: o2 not of in second sentence, no cat, or o2 after cat, thats why o2 code is there. 1/4 tank of top grade fuel, fuel pump has about 200 miles on it and i did it about 5 mo ago, i didnt drive it for winter, car has 3 in drop. i was broke and cam and crank sensors were all bad, i didnt drive it much untill today.
Old Apr 4, 2015 | 06:25 PM
Mateen995's Avatar
seems like a really common on problem on these 4th Gen's
from what I've seen it could be your MAF or IACV
Old Apr 4, 2015 | 06:35 PM
kjlouis's Avatar
maf will throw a code wont it? i think im gonna take off iacv and clean it tomorrow, i took it off while doing injector and there was actually a gap in the silicone gasket, but i looked up on google a little bit ago and it mentioned a service bulletin from sept 99 about the main wiring harness, i feel like this is something is bad not just intermittent wire issue because this is every time i start it. bullitin classification ec97-018b ref no ntb98-008b, sept 16 1999 thats not my problem here right?
Old Apr 4, 2015 | 07:39 PM
Mateen995's Avatar
MAF's may or may not throw a code, they're weird...
& that service bulletin is not your problem
Old Apr 5, 2015 | 02:39 PM
njmaxseltd's Avatar
Something isn't right with you OBD diagnostics. If the cam and both crank sensors came up bad, the car would have never started.
Scan again and post your findings. Clearly you have a misfire or the MAF is failing.
Old Apr 5, 2015 | 03:06 PM
Mateen995's Avatar
I've had a bad cam sensor & the car started until the sensor got warm then it stalled
But you should scan again
Old Apr 5, 2015 | 04:38 PM
njmaxseltd's Avatar
Cam sensor control fuel injector timing, if it's bad the car will run a default fuel timing map based on the crank position.
If crank POS is bad you'll get a no start condition.
Old Apr 8, 2015 | 12:09 PM
kjlouis's Avatar
I got crank pos and crank ref were bad I replaced them and in my grandpas driveway ran his scanner and pulled 02 (that is always pulled cus no of sensor after cat because no cat - previous owner) @and cam sensor a bad I'll run to autozone n scan again. Off topic does anyone have a link on how to wire the 2 bulb headlight system instead off 1 bulb? I think I blew a fuse any time light were on brights indicator was on n driver side went out last night. Any time I hit brights they just come in but they all dim. Back to topic. Once it's warm it don't die any more but 8 it drops to idle about 2/3 of the time it's missing like crazy for a few seconds.
Old Apr 8, 2015 | 01:57 PM
kjlouis's Avatar
P0325 knock sensor
p0340 cam sensor bank 1
p0340 02 sensor (af ratio sensor) sensor 1 bank 1
That cam sensor is the one on side of engine near water pump right? It's brand new. 2 days old.
thatcollegestudent
18
Oct 5, 2015 02:29 PM
cruce91
Sep 20, 2015 10:23 AM
97_GXE
Sep 15, 2015 06:47 AM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
