Adding Digital temp gauge
Old Apr 8, 2015 | 09:32 PM
maximaham's Avatar
Hi has any body add a digital temperature gauge to there 4th gen.
also what gauge pod fits on the side piller. pictures welcome
Old Apr 9, 2015 | 12:36 PM
maximaham's Avatar
No one
Old Apr 9, 2015 | 01:56 PM
Fakie J Farkerton's Avatar
I have one.
Innovate had a dual gauge that shows voltage and water temp so I installed that with my AFR in a dual gauge A-pillar pod purchased from a part out.
I went to Z1 online and ordered an adapter to put on the hose that held the sensor.
I believe most just use an OEM spot though, but I wanted to leave it alone.
Old Apr 9, 2015 | 02:37 PM
NmexMAX's Avatar
dot dot dot ...
I sort of had the same on my 5.5 gen. Used the ECU signal wire from the VSS, ECT, MAF, RPM and IAT (2 speed signals, and three 0-5v inputs). Tapped the ECU wires, and used the FSM for voltage/hertz to whatever unit conversion curve and it was actually quite swell. Doing just the ECT should be easy, as FJF said.
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
jaydot901
Sep 29, 2015 01:18 PM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
