P0755 shift solenoid valve b
Old Apr 29, 2015 | 04:58 PM
maxfever1987's Avatar
I have a p0755 which is shift solenoid b in the transmission valve body inside the transmission oil pan, my question is has anyone here this issue? And is it possible that the solenoid is simply dirty?
Or is it most likely needed to put a new solenoid in there, I don't mind changing the part but it's the cost of the actual part itself that makes me wonder if cleaning it would do the job
Old Apr 29, 2015 | 10:50 PM
vqmaxman's Avatar
It can be just the solenoid or the valve sleeve getting stuck. The best thing you should do is check and see if your car shifts through all the gears,with this function you are most likely to run 1,2-3,4 or 1,2 or 3,4 if I remember correctly the 1,2 are the a valve and the b valve is 3,4 only.
Old Apr 30, 2015 | 08:00 PM
The car is drivable but it doesn't shift through gears properly, it's in limp mode so it's in 3rd gear at all times,
Old May 1, 2015 | 12:45 PM
theWalkinator's Avatar
Have you check your trans fluid? I would go buy a can of Seafoam trans-tune and pour half can in.
Old May 1, 2015 | 05:53 PM
jholley's Avatar
You can test the resistance of that solenoid on an external connector.
http://maxima.theowensfamily.com/tsb/NTB98-043.pdf
Disconnect connector F42 and measure the resistance for solenoid B. The resistance range is 10 to 20 ohms. Connector F42 is loacted behind the parking pawl.
Solenoid B: Pin 1 and GND
If it doesn't measure within that range then replace the shift solenoids using this thread.
https://maxima.org/forums/4th-genera...solenoids.html
They cost less than $90.
If it measures between 10 to 20 ohms then that solenoid is fine.
As suggested add in some trans treatment then perform a non-pressurized 10 quart flushing. You'll find details on that flush in the Fluids & Lubricants Forum (how to flush ATF...)
Old May 1, 2015 | 06:18 PM
Thanks for all the help so far everybody,
one question though, is it a better idea to go with the new $90 kit or simply the original kit which is literally $405.00 which I found out abt by calling the dealer today,
Are both the same exact parts?
Old May 1, 2015 | 07:21 PM
jholley's Avatar
They're the same. That upgrade kit is collecting dust so they're selling them at clearance prices. I inserted them 3 years ago along with a Transgo shift kit.
Old May 13, 2015 | 05:55 AM
I got the new part in today, I'll be installing today as well, just gotta study the procedure a lil bit
Looks pretty straight forward only thing that's tricky is the manual valve shaft thing,
Old May 13, 2015 | 08:30 AM
I got everything out now I'm going to be installing it back in, but a question where does that big spring go on the control valve assembly it came out during removal now I don't know where it goes back in,
Can you tell me where to place it?
Old May 13, 2015 | 08:51 AM
And also there's a small spring as well, where does that one go
Old May 13, 2015 | 08:56 AM
jholley's Avatar
Here's placement for the large spring
Old May 13, 2015 | 08:57 AM
jholley's Avatar
For that small spring view the top right figure on page 4 of this manual
That small spring is seated behind the Line Solenoid. On the far end of the main VB there are also 2 mid sized springs with ***** on top for controlling the pressure.
Old May 13, 2015 | 03:06 PM
Thanks for that, I only had 2 springs come down which were the big large one and the one after line solenoid was removed,
1 other questions, since I didn't remove the transmission from the engine I will have to hold the big spring into place wile reassembling the control valve assembly,
What's the best way to hold it in place while securing the vc assembly back? Simply place it onto the cv and hold it steady in place and tighten the bolts hoping it went in securely ?
Old May 13, 2015 | 04:13 PM
jholley's Avatar
That's how I got back on.
Note the 21 pan bolts only require little torque for tightening.
Old May 13, 2015 | 04:19 PM
Lol working against gravity and holding that heavy vc assembly is not fun,
Btw any certain way to position that bracket with the bolt for line pressure solenoid? Kinda looks weird when I put it back on, it doesn't go in between the line solenoid right?
Old May 13, 2015 | 04:25 PM
jholley's Avatar
Heres how the line solenoid bracket is positioned
When I first disassembled a VB that bracket location got me stumbled.
Old May 13, 2015 | 04:30 PM
I must have stared at your pic from another thread for about 10 mins and saying to myself wat is the purpose of it being positioned like this? Because if you see the fsm http://maxima.theowensfamily.com/tsb/NTB98-043.pdf it on page 4 it shows it as if it's literally going through the solenoid
How many quarts did you fill back in after this install looks like to me it needs abt 10
Old May 13, 2015 | 04:40 PM
jholley's Avatar
The bracket in the owens diagram is the one seated onto the line solenoid. The loose corner bracket doesn't appear in the diagram. Why it's seated like that is my mystery also?
With the pan and VB dropped I only added ~8 quarrts. The TC holds a few quarts of ATF.
Old May 13, 2015 | 07:55 PM
vqmaxman's Avatar
The tranny takes a total of 16qts,torque converter takes about 2qts,the rest is on the tranny. The little spring your talking about that goes into the spot where the solnoid goes. The vb has two little metal ***** to that go in the valve sleeve. That's if they didn't come out while you were fiddling around with the other things.
Old May 13, 2015 | 09:17 PM
I didn't see any while disassembling, curious though, where exactly would they be located just so I can verify they are still in place, I am not a fan of doing this again haha,
Old May 14, 2015 | 05:11 AM
jholley's Avatar
What tranny are you talking about? The RE4F04A only takes a total of 10 quarts. That's stated in Maintenance FSM. Dropping VBs or while performing non pressurized total ATF flushes I never needed more than 10 quarts.
Old May 14, 2015 | 05:15 AM
jholley's Avatar
Sounds like you just replaced the solenoids. You'll only find those extra springs while disassembling the VB. The two I was referring two are located under the ***** on the bottom left of this VB above that open square.
As seen in the bottom left of that photo is an arrow pointing to that loose corner bracket.
Old May 14, 2015 | 01:56 PM
DBear's Avatar
When I changed my solenoids I asked the same question, and was told to use a dab of vaseline to hold it on the plate. That worked for me.
Old May 14, 2015 | 05:30 PM
vqmaxman's Avatar
I mean't you will need 16qts doing the powerpurge flush on the tranny. The drain and refill you will just need 10qts. The cooling lines and the inner tranny lines take a chunk of the fluid.
Unclejunebug
Apr 2, 2016 05:42 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
