need help with rear speakers
Old Jan 25, 2002 | 09:27 PM
maxmacxxii
hey, i'm new to the forum. my parents got me a maxima, but it doesn't have bose. i bought some rear speakers cuz the factories were garbage, but i don't know how to put them in. i'd appreciate if someone could tell me how i take the current speakers out of my trunk and put the new ones in. thanx!!!
Old Jan 25, 2002 | 09:30 PM
Kashoggio's Avatar
www.maximadriver.com or do a search
Old Jan 25, 2002 | 09:36 PM
95emeraldgxe's Avatar
basically all u gotta do is get a putty knife to pry off the grilles......then just unscrew the speakers......drop in the new ones......use a harness if u want to make the job easier and then snap the old grilles bsck on
Old Jan 25, 2002 | 09:37 PM
Sprint's Avatar
Old Jan 26, 2002 | 12:27 AM
1MAX2NV's Avatar
Hmm..I though you have to remove the panel on the rear deck?
Old Jan 26, 2002 | 02:04 AM
Nismo's Avatar
the grills are screwed on
Old Jan 26, 2002 | 04:54 AM
MaineMax's Avatar
search is your friend.
OK - You need to remove the back seat and shelf to get to your rear speakers.
1.) Remove the rear seat bottom cushion. ( Pull on the 2 plastic rings on each edge. )
2.) Remove the 2 bolts on the outside edges of the seat back.
3.) Fold down the arm rest and door behind the arm rest. Lift the carpet and remove the 2 bolts. Push up on the seat back to remove.
4.) Remove the 3rd brake light assembly.
5.) Pull back the door edge molding.
6.)Pry out on the rear pillar trim panels to release the clips. Let them hang by the rear seat belts.
7.) Pry up the rear deck panel and slide it toward the front to remove.
8.) Now you can get to your speakers
Good luck.
Old Jan 26, 2002 | 07:48 AM
gtr_rider's Avatar
192.168.1.1
It starts by pulling on the 2 tabs located on the bottom of the cushion. You just have to pull on the tabs and lift and the seat should come right out.
now when the bottom of the seat is removed 2 bolts are revealed on each side of the seat. I don't remember what size they are.
there are 2 bolts behind the armrest, remove these and the seat should come out.
Once that is off all you need to do is remove the rear deck. To get it off, you have to remove the side panels by the rear passenger windows that hold the rear deck down. Both panels are a pain to get off, you just have to bite your lip and pull hard.
Be careful when removing the panel the seat belt thing is sensitive to pressure be careful not to break it.
make sure you disconnect the rear dash brake light
connector before you remove the rear deck
from inside the trunk, you may need your pliers here, pop these up (I think there are 3 of these pins), and the deck should come out.
to remove the speaker from the car there are 4 three screws (I believe they are Philips), and disconnect the amp.
Old Jan 26, 2002 | 11:13 AM
lol - everything is harder on the maxima.....screwed in grilles.......having to drill a hole in the fenderwell to install the cai.......clearing out taillights(95-96)......but eh - i'm still happy....i guess its better to make it harder......more theft deterence
matts95max
Apr 23, 2025 10:44 AM
9aj9
Apr 5, 2020 12:11 AM
bbsitum
Sep 11, 2015 04:55 PM
A32goldylocks
Sep 2, 2015 06:39 AM
