turbo VS summer
Old Jun 10, 2015 | 11:26 PM
maxam's Avatar
turbo VS summer
Good day all
You know that in the middle east the temperature now is rising.
In these days it reaches 45 Celsius. Life without A/C is just like
Throughing myself into the oven.
I have disconnected fans temp sensor so the fans starts
At their full speed . Drove my car for two hours the temp reached
220f with A/C on . Thats really dangerous status for turbo cars.
Ok so Im trying to modifie the fans to get better cooling .
Any suggestions ?
Hi speed motor fans ??
Blades ??
Extra fan ??
Thermostat ??
For your info
I have moshimoto rad
Old Jun 10, 2015 | 11:33 PM
bumpypickle's Avatar
Originally Posted by maxam
Good day all
Any suggestions ?
Blades ??
Extra fan ??
Thermostat ??
For your info
I would wire a switch that controls your fan. That way if it gets too hot, just pull over turn off engine and flip switch. Alternatively, you could just not use your ac.
Old Jun 10, 2015 | 11:46 PM
Huge all aluminum radiator ( ie griffin, maybe mishimoto)
Add a bottle of Water Wetter
80% water, 20% coolant mixture
Old Jun 11, 2015 | 01:28 AM
maxam's Avatar
Thats funy . I will burn my self without AC.
Any alternative fan motors thats more powerful than OEMs
Old Jun 11, 2015 | 02:55 AM
dwapenyi's Avatar
You should find this old thread useful....
https://maxima.org/forums/general-ma...-temp-mod.html
Old Jun 11, 2015 | 05:04 AM
zillafreak's Avatar
Once you are cruising, a fan really doesn't help with cooling. A fan's job is to pull/push air when the car isn't move fast enough.
You best bet is to run a big radiator, also look into running an oil cooler.
What oil do you run? In a past car I drove (stock turbo), it would fry cheap oil. I had to run synthetic 0w40.
Last is the tuning, is the car running lean, or very rich? This can cause the engine to overheat too.
Old Jun 11, 2015 | 05:06 AM
Max_Gator's Avatar
It sounds like he's already running the fans full bore all the time.
I would confirm that both fans are indeed running. Then I'd add the water wetter and make sure the cooling system is fully bled correctly. You can find instructions in this forum. Do it correctly.
Finally I'm fairly certain that there are aftermarket high performance fans. Now whether they fit with your turbo setup, I don't know.
And . . . damn it is hot out there.
Old Jun 11, 2015 | 08:34 AM
vipervadim's Avatar
I like Maximas
Here's a few suggestions based on your Environmental factors:
1. First take a look at the A/C condenser - it gets clogged with sand and other road debris. Since condenser sits right in front of the radiator, it will prevent a lot of air flowing into radiator when it's clogged. Replacing a clogged a/c condenser will help bring more air to the radiator. Make sure your mishimote Radiator is not clogged either.
2. Electric fans which flow much more CFM - They DO have bigger Current draw, that requires a bigger relay and better gauge wiring to support it.
http://www.ebay.com/itm/11-Dual-Extreme-Electric-High-Performance-Radiator-Cooling-Fan-Twin-HD-Puller-/160822306344?hash=item2571c1a628&vxp=mtr
3. HELP THE TURBO. to help with power and engine reliability, it would be great to cool the intake charge and run boost SAFER and LONGER in HOT temps by adding a water/meth injection kit.
http://www.jegs.com/p/AEM/AEM-Water-...34884/10002/-1
Build it right and enjoy it
Old Jun 11, 2015 | 08:43 AM
Quickywd01's Avatar
For your info
Can you post a quick pic?
Old Jun 13, 2015 | 11:20 AM
maxam's Avatar
11" Dual Extreme Electric High Performance Radiator Cooling Fan Twin HD Puller | eBay
well , its totaly messed up , because drive it only for maintenace or washing it onece a year
the fans are out of stock , but I have two mishimoto fans that came with my radiator and I installed them .
I have replaced the water of the radiator , it was 50-50 , now 20 grean 80 clear .
I started the car with A/C for 20 minets ,but did not drive it because the weather was good this night, and it did not go Above 190 F.
i will test it on the day time on hot weather .
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
09maxshawn11
Sep 30, 2015 10:28 AM
