1995 Nissan Maxima speaker issues
Old Jun 26, 2015 | 12:17 PM
carguy96's Avatar
I have a 95 maxima GLE with the stock bose speakers and original radio. The raido turns on and off, but i hear no sound from the speakers. Occasionally, if i hit a bump hard enough, the speakers will turn on and play sound, however, 95% of the time, the speakers will not work. I think there might be a loose wire somewhere; is there any way for me to checks this? Thanks.
Old Jun 26, 2015 | 12:23 PM
DennisMik's Avatar
Loose wire? You wish you could be that lucky. Sorry to rain on your parade.
You have 4 speakers and 4 sets of wires. The only one thing they have in common is the radio itself. It is a Bose and it is dying, showing one of the typical failures. You need to replace the head unit.
Old Jun 26, 2015 | 12:46 PM
carguy96's Avatar
The head unit as in the actual radio part itself? How much would one cost?
Old Jun 26, 2015 | 06:39 PM
DennisMik's Avatar
The radio is the head unit. The radio has evolved into more than just a radio. It is also a tape player and a CD player and and a navigation unit and more, the term head unit is being used.
If you price a brand new Bose head unit, it is (are you sitting down?) $2300, discounted to $1900. You probably don't want to do that.
You can go out on e-bay and get used units that seem to be in the range of $100 to $200. But you are getting a 20 year old unit that is going to fail in the near future.
Start looking at aftermarket radios like sony, kenwood, jvc etc. You have choices from $100 and up to $1000 and maybe more. But you will need A trim adapter, an antenna adapter and a line level adapter. For $200 you can get a decent radio with all these adapters. Check out crutchfield.com.
Old Jul 1, 2015 | 09:26 AM
bigd480's Avatar
If you want plug/play solution on the cheap, there is a 2006(?) pathfinder Bose 6-disc in-dash model that works directly - just need to drill new holes in mounting brackets and maybe tap a wire. Those can be found cheapish on ebay/forums.
halfpol
Oct 17, 2022 12:16 PM
ah2002
Mar 9, 2016 01:42 PM
xUNIxPanther
Aug 27, 2015 10:09 PM
julian888
Aug 6, 2015 04:39 AM
halfpol
Aug 5, 2015 08:24 PM
