ripped a flex pipe a bit
Old Jul 8, 2015 | 03:20 PM
CautiousDriver's Avatar
Guys i was thinking to wrap a bit of exhaust tape around that hole, it's right at the beginning section of the flex section. went upstate and caught a high rock. Buying new or used and installing is also an option , but i would like to avoid it.
thought about that exhaust tape. would it work ? thanks for any experience shared!~
Old Jul 8, 2015 | 05:06 PM
Daniel VQ30life's Avatar
probably won't last long, it's on a flexible piece
I've never used it before nor have i ever been recommended to use it
Old Jul 8, 2015 | 08:07 PM
Its very noisy so figured maybe it will deaden the noise a bit. Provided it holds...
Old Jul 10, 2015 | 09:02 AM
DennisMik's Avatar
The tape will probably work for a while, but it will eventually come loose and fall off because of the pipe flexing. How long the tape will hold is anyone's guess.
Old Jul 10, 2015 | 09:49 AM
Ok ill try untill i find another y pipe. Thanks guys.
Old Jul 13, 2015 | 09:45 AM
Cebby's Avatar
I just had this develop on mine - taking to a shop that does custom exhausts to see if they can replace the flex section - on Warpspeed Y (everything behind that is stainless). Did you think about hitting an exhaust shop to replace just that section?
Old Jul 13, 2015 | 11:00 AM
i did just that but that shop quoted $250. keep in mind it might rust out 3years or less. so i recommend spraying some heat resistant exhaust spray on those welds. let me know what you get quoted, maybe I'll go to queens where i did some work before.
Old Jul 13, 2015 | 01:59 PM
KP11520's Avatar
Just had mine done today at American Muffler in Westbury, NY for $150 plus tax. They cut it out and Mig weld in a new one.
Factory replacement for an original at the dealer is STUPID money.
I hope this helps!
Old Jul 15, 2015 | 02:35 PM
Cebby's Avatar
Just got mine back - $213. $168 shop labor + $45 parts
I had heard that the Warpspeed Y flex sections didn't last + I bought mine used so I don't know how much abuse it endured before I got a hold of it. I can report that the braided covering on the flex pipe was all ripped up on mine which might have been the indicator of its demise.
They added a slight bend to the end of the y-pipe for better alignment and welded in a shorter flex section. They opted to weld the y-pipe to the cat to eliminate one of the flange junctions - didn't see an issue with this since my cat is only a couple of years old.
Old Jul 15, 2015 | 03:01 PM
Yeah buying a used pipe is a better option. Thanks for the feedback
Old Jul 15, 2015 | 06:31 PM
jholley's Avatar
The flex section on my 7 year old SS WS Y-pipe cracked on me last winter. As mentioned earlier that flex section was not SS like the piping and flanges.
I purchased this SS flex pipe off ebay for $20 http://www.ebay.com/itm/171150642265...84.m1436.l2649
With the 2.5" x 8" pipe slid over the mounted y-pipe sections I arc welded a few sections to hold it on while dropping the y-pipe. After dropping the y-pipe I mig welded around the entire flex pipe on both ends. I then sprayed the entire SS y-pipe with exhaust primer & paint.
For members with the welding tools I highly recommend that SS flex pipe made by bearriverconverters.
Old Jul 15, 2015 | 07:32 PM
Ah very cool that might be a solution!
Old Jul 16, 2015 | 02:33 AM
if you want a stock y pipe, I'll have one available next week, is 97 fed
Apr 16, 2020 05:15 AM
Quickywd01
Sep 21, 2016 09:36 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
