Fluids for a 95 Max
Old Nov 13, 2000 | 01:01 PM
Retro
Just some quick question regarding fluids on a 95 Max GXE.
-Is the red **** dipstick (to the the right of the engine) for the tranny fluid? If so, where would I fill that if it was low?
-What fluid goes in the container just behind/above the coolant (all the way to the left under the hood)?
These might seem like dumb questions, but I'm a new driver who's barely had a chance to "learn" every thing bout the Max yet within the 3 wks I've had it and my owner's manual hasn't arrived yet.
Thx.
Old Nov 13, 2000 | 01:49 PM
Chunger's Avatar
My other car is a Hybrid
Correct on auto trans fluid...
I believe you fill it thru that dipstick tube... DON'T OVERFILL... wait for your manual or someone else here on the forum... I'm not much into slushboxes..hehe
The reservoir just rear of the coolant s/b for the power steering fluid.
Old Nov 13, 2000 | 01:56 PM
Retro
Re: Correct on auto trans fluid...
Thx a lot =) Tranny fluid is ok, but time to pick up some power steering fluid....
Old Nov 13, 2000 | 02:03 PM
Synki's Avatar
Yep, the red ball thing.. hehe is the dipstick for the trans. That is also where you would fill. The other thing your talkin about is the power steering.
Old Nov 14, 2000 | 01:12 AM
mrloyd
proper
when checking any fluid there are ways to do it right. These procedures have a huge impact on the results. Go and get a SERVICE manual, the factory OWNERS manual is insufficient except for very general things. You could get the factory service manual for about a hunderd dollers or a haynes which i have for about 15. For checking power steering fluid you should turn steering wheel lock to lock then leave in center and check with engine off. For auto tranny fluid you should start engine, run gear shift through all gears, put in park and check with engine at idle. Reading will be wrong if you have been driving for a long time, in such case allow to cool some.
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
fastcarny
Oct 12, 2015 07:06 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
pktaske
Sep 4, 2015 08:40 AM
