HELP! 4th gen manual trans conversion using 5th gen parts.
Old Aug 8, 2015 | 02:33 PM
ef9's Avatar
ef9
I'm trying to swap in a 2000 manual trans into my 1996 I30.
I didn't know the clutch pedal between the two are different!
Do you know if the brake pedal is different too?
Old Aug 8, 2015 | 02:42 PM
Nealoc187's Avatar
SLOW
i didn't know it was different either. pics of the difference?
Old Aug 8, 2015 | 02:52 PM
ef9's Avatar
ef9
Old Aug 8, 2015 | 02:53 PM
ef9's Avatar
ef9
Of course, I do not have the 4th gen clutch pedal to show a picture of.
The mounting points inside of the car is obviously different.
Old Aug 8, 2015 | 03:18 PM
ef9's Avatar
ef9
Here is the 4th gen mounting for the clutch pedal:
Old Aug 8, 2015 | 03:19 PM
ef9's Avatar
ef9
Here is the mounting for the 2000 Maxima:
Old Aug 8, 2015 | 04:59 PM
max ride 41's Avatar
looks like your walkin for awhile...
Old Aug 9, 2015 | 07:07 PM
DennisMik's Avatar
The 2000 has a different body so I can believe that the clutch pedal is different. The brake pedal probably is, too.
Old Aug 9, 2015 | 07:56 PM
vingodine's Avatar
Yes, the 4th gen and 5th gen brackets are both different. If you look at the FSM diagram you can see a difference.
This applies to both the clutch and brake pedals.
Old Aug 10, 2015 | 08:05 AM
dwapenyi's Avatar
So all you need is the clutch pedal from a 4th gen. I assume you have the clutch fluid reservoir already?
Goto car-part.com
Search for a Brake/Clutch pedal for a 1995 to 99 Maxima.
Find the one with your clutch pedal....they will be rare.
Alot of junkyards should pop up. Call and talk to them to work out your best deal.
Old Aug 10, 2015 | 08:22 AM
aackshun's Avatar
Goto car-part.com
TBH this is a waste of time. You will get frustrated quickly that way.
To save a lot of time do it like this:
Look up manual transmissions, then ask if the car is still there. Better way of doing it.
Most likely you're gonna find a bunch of transmissions on the shelf, but at least you won't get hanged up on and slightly better service this way.
The best way is local pick and pulls. Online partouts. What about that 4th gen parts guy on here???
Old Aug 12, 2015 | 01:46 AM
dwapenyi's Avatar
Maybe talk to this guy about the clutch pedal........better do it quick;
https://maxima.org/forums/4th-genera...gen-parts.html
Old Aug 12, 2015 | 05:00 AM
95naSTA's Avatar
I'm not sure it the pedal and spring are interchangeable but I bought a new 4th gen bracket for $60 shipped last year.
p/n: 46550-40U00
Old Aug 12, 2015 | 09:12 AM
ef9's Avatar
ef9
I have both pedals en route to me as we speak.
Thank you all for your help!
Old Aug 13, 2015 | 01:19 AM
ef9's Avatar
ef9
Question:
On the 4th gen clutch pedal. The way it mounts is via the 2 bolts for the clutch_master_cylinder and a 3rd bolt. On the front of the clutch pedal bracket, there is a threaded nut-sert for a 4th bolt, but I don't see how that bolts up in my car.
Any help on this? I don't have a picture to provide because the clutch pedal is installed in my car.
stevesmax
Dec 17, 2020 11:57 AM
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
t6378tp
Aug 24, 2015 07:03 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
