anyone got a camber kit?
I was talking with my friend and he insisted that if i drop my car with kyb agx struts and b & g springs, and add on 17's they will wear more in the center or outside of the tire do to the camber being off.....before i get my suspension stuff, should i consider the camber kit????
Re: anyone got a camber kit?
(Btw, lowering causes "negative camber" which if excessive, can cause premature wear on the "inside" and/or center tread blocks, not the outside)
Re: Re: anyone got a camber kit?
Originally posted by hooktup98SE
i've got a camber kit on mine... but then again mine is dropped alittle over 2" ... (two fingers depth gap in the wheel well)... gotta protect my investment right? (tires)...
Re: Re: Re: anyone got a camber kit?
Originally posted by nigelcmf
How much are camber kits and where to buy? I am considering getting coilovers.
I have the camber bolts for my car (Ingalls) and I hate them. Even tightening them up to 80lb/ft, they tend to loosen over time and I have to adjust them every now and then. Pretty disgusting when I am driving and then suddenly my steering wheel is crooked because the stupid camber bolts have loosened up on me. I called Ingalls and they said, "yeah that happens sometimes." Unacceptable response. And I will probably remove these and just eat the cost of uneven tire wear to save me the hassle of these useless bolts. I would not buy them unless you have a bad camber problem.
Re: Re: Re: Re: anyone got a camber kit?
Originally posted by Eric L.
If you get coilovers, you do not need a camber kit, as the coilovers come with a camber adjuster plate already.
04-16-2020 05:15 AM
Kyle Lee Cleveland
09-28-2015 07:58 AM
Pied
09-26-2015 03:29 PM
