Failing Ignition coils, starter, or injectors?
Old Sep 9, 2015 | 12:42 AM
97_GXE's Avatar
ExcusE me I disappear for awhile, then have to make 2 threads in 1 day...
Most common when car has warmed to operating temp...and overheating and 90+ degree days aren't helping. Important to note, it doesn't do this all the time...but it's happening more and more. The hotter it is outside, the harder it is to start.
I'll crank it, it may sound scratchy and grinding...or sometimes it'll take 3-4 seconds to start...stalls, or makes a sound like a dj spinning a record, then stalls. Or it'll start with an explosion which causes me to feel the engine shook way too hard to get going.
This seems to worsen as my oil and throttle body gets dirty...but I've not had this much issue starting some of my previous older cars. This is about the only on-going hard to find issue.
Anyone object to me pouring a can of "restoration" in the engine, and sea foam in the fuel tank? I already bought some.
Old Sep 9, 2015 | 01:22 AM
Maxima 97 SE's Avatar
Most likely a bad fuel injector that has had its Pintle cap broken which keeps the o-ring intact so the fuel injector throw the right amount of fuel but since the cap Pintle cap has broken it's just dumping in a lot of fuel and the fuel is just leaking past the o-ring.
Old Sep 9, 2015 | 08:47 AM
cashoit's Avatar
do u have a CEL? what are the codes? any one of those issues should throw a code.
Old Sep 15, 2015 | 12:21 AM
97_GXE's Avatar
Thanks for the suggestions...
I had a mechanic do a code Scan for me. It pointed to the (if I can remember now, it's been awhile), the crankcase censor. I changed that myself, and replaced with new. It kinda helped, but not really.
I started it up today when sitting for a couple of days, it started right up as usual. It's just when it gets hot...oh, another thing is when I get empty on fuel, let it sit overnight...it's almost impossible to start up. It doesn't want to crank over, so I try to never let it get to under 1/2 of 1/4 a tank.
Old Sep 15, 2015 | 12:39 AM
I fixed the 1/2 of 1/4 a tank problem with replacing the fuel pump with an oem original nissan pump out of an infiniti i30. Now the car cranks up right away when low on gas.
Old Sep 15, 2015 | 06:47 AM
97_GXE's Avatar
Yeah when I'm at yards, I always pull i30 parts first, especially interior pieces. Infiniti owners generally took better care of things haha.
But I know it's generally not good to run an older car low on gas anyway due to tank gunk, and the fuel filter overheating.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
AaronL
Aug 8, 2020 10:31 AM
maxima297
Sep 30, 2015 03:32 PM
zmcneely13
Sep 26, 2015 02:26 PM
