Bleeding breaks on the 4th Generation Nissan Maxima
Old Oct 25, 2015 | 09:59 PM
Terryw's Avatar
Hello My Name is Terry and i have a question that i hope some one can answer for me.
Bleeding breaks on the 4th Generation Nissan Maxima is it the same way as all other cars or is their a set pattern you need to do?
Old Oct 25, 2015 | 10:08 PM
ef9's Avatar
ef9
Same as any other car. I have a 96 with ABS, and I had no problems at all bleeding the brakes and flushing out the old brake fluid.
Old Oct 26, 2015 | 03:26 AM
BronxSleeperMax187's Avatar
Maybe not...Bleed the brakes in the following order:
1. Passenger rear
2. Driver front
3. Driver rear
4. Passenger front
Old Oct 26, 2015 | 08:34 AM
maximusrising's Avatar
1. Passenger rear
2. Driver front
3. Driver rear
4. Passenger front
X2
FSM Section BR, page BR-6, Bullet Point #5
and I suspect not the same, necessarily, car-to-car. However, if you get all the air out.... then it's right. Following the sequence increases the likelihood. All about distance I think. So how it's plumbed determines the farthest, etc.
Old Oct 26, 2015 | 07:58 PM
Terryw's Avatar
Bleeding breaks on the 4th Generation Nissan Maxima 2nd try
well guys i have bleed the breaks like
1. Passenger rear
2. Driver front
3. Driver rear
4. Passenger front
so i had no luck no breaks yet so i gave it a second try and making sure i bleed each break i would fill the fluid be for bleeding the wheel now im starting to wounder do they have to be vacuum bleed? and i really appreciate
every ones help cause im stumped on this one.
Old Oct 26, 2015 | 08:10 PM
no they don't have to be vacuum bled. Are you seeing bubbles when you're doing the bleeding?
and brakes>breaks
jholley's Avatar
1. Passenger rear
2. Driver front
3. Driver rear
4. Passenger front
Did your assistant keep their foot on the brake pedal before you close the bleeder screws? Otherwise you'll leave air in the brake system. I vacuum mine with the mighty vac bleeder.
Edit: Another alternative is to have speed bleeder valves installed. They have check valves on them.
Old Oct 26, 2015 | 08:39 PM
Terryw's Avatar
both of the guys i had helping me said they keep the peddle to the floor till i said ok. and it is a sold stream of break fluid that comes out
Old Oct 27, 2015 | 12:08 AM
ef9's Avatar
ef9
I used the one-man bleeder (it's just a clear tube that goes to the bottom of a plastic bottle.
I bled them myself, but I didn't follow the sequence in the FSM. But I do have firm pedal pressure. And I was able to purge all of the old brake fluid out of the reservoir and lines.
I put grease around the bleeder screws to prevent air from going back in. I tried a Mityvac hand pump, but that didn't work the first time around. So I used the one-man brake bleeder bottle. That worked.
Lakersallday24
Jun 16, 2019 01:35 AM
josephbolden91
Oct 29, 2015 07:02 AM
wellz
Aug 26, 2015 09:05 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
