Strut bearing question
Old Oct 24, 2015 | 05:35 PM
dsonnylal's Avatar
Does anyone use any kind of lubricant grease for a new OEM strut bearing?
If so, what type of grease?
Old Oct 25, 2015 | 11:06 AM
DennisMik's Avatar
It is a sealed unit, not designed to be greased/lubricated.
Old Oct 26, 2015 | 06:43 AM
M in KC's Avatar
^What he said.
Old Oct 26, 2015 | 08:28 AM
njmaxseltd's Avatar
The bearings easily pop apart, use a small flat head and pry gently.
There's a plastic "bearing" slider inside. Clean it up and grease it with white lithium or standard wheel bearing grease.
Old Oct 27, 2015 | 03:33 AM
Diesel_hunter's Avatar
Use only lithium grease designed for use with bearings not white grease, i prefer nlgi #2 amsoil (red) it is designed to hold up to heat and pressure, white grease is is for applications where heavy moisture is present, not for packing bearings
Maximum_Carnage
Mar 21, 2016 07:38 AM
MAXIE06SE
Oct 25, 2015 05:11 PM
Heat0212
Oct 19, 2015 06:39 PM
09Maxima_Sam
Oct 18, 2015 08:32 PM
