EGR tube no alignment to manifold
Old Nov 1, 2015 | 05:53 AM
ik95's Avatar
Did I miss something. I changed the rear value cover plus cleaned EGR tube, now but manifold and EGR tube does not align to it??
Old Nov 1, 2015 | 06:14 AM
ik95's Avatar
there is about a 2 inch space in between? is there a gasket?
Old Nov 1, 2015 | 09:36 AM
JvG's Avatar
JvG
I've replaced both of these. I'm having difficulty understanding what is going on. Do you have a better description? A picture,.?
Old Nov 1, 2015 | 08:35 PM
JDezMax95's Avatar
I remember doing this job and this happening. I believe that I bolted the tube upside down once and it would not align, then I flipped it and it fit. Perhaps that's also your issue.
Old Nov 2, 2015 | 08:53 AM
Turbobink's Avatar
As I recall, it's quite easy to tighten the lower guide tube flange at the incorrect position, thereby creating the gap you're talking about in the upper flange.
Very loosely attach all of your mounting nuts.
With everything loose, position/mate the upper flange as necessary (don't forget the gasket and nut spacers) ... tighten the upper flange.
Then tighten the lower flange and you should be good to go.
Old Nov 3, 2015 | 06:02 PM
ik95's Avatar
This was it. I loosen the bottom bolts and align them all and it worked.
twinturbo3
Dec 24, 2017 07:43 AM
t6378tp
Dec 2, 2015 12:42 PM
mattz300
Nov 11, 2015 11:53 PM
t6378tp
Nov 11, 2015 04:45 PM
1NICEMAX
Oct 29, 2015 03:42 PM
