how to remove EGR valve
Old Nov 1, 2015 | 05:14 PM
pancho510's Avatar
I have a 97 Maxima automatic I need to clean the EGR valve.
Do I need to remove the manifold to get access to the EGR and pipe???
Old Nov 1, 2015 | 05:39 PM
JvG's Avatar
JvG
Most of the how to do somethings are in the stickies at the top of the page. how to......
using the search feature is helpful as well.
No, the manifold can stay on. a hacksaw will be needed to cut through a bolt.
Old Nov 1, 2015 | 05:57 PM
pancho510's Avatar
ok thx
Old Nov 1, 2015 | 09:38 PM
bumpypickle's Avatar
I cleaned my pipe and sensor using this link:
https://maxima.org/forums/4th-genera...ing-p0400.html
Unfortunately, my code p0400 was not fixed after cleaning both parts becuase the previous owner had replaced both parts and were fairly clean already.
So researched on the forum and decided to replace the EGRC vacuum solenoid. after doing so, my code went away after clearing it.
link to location:
https://maxima.org/forums/4th-genera...oid-valve.html
Hope this helps, also when taking off the iacv,throttle body, and maf. Clean them with with the correct solvents, if you haven't already to help smooth out your idle. Make sure to clean the intake manifold entrance when the throttle body is off as well as the areas where the egr tube connects.
02whitemaximase
Nov 28, 2018 07:42 AM
Desorath
Dec 7, 2015 07:57 AM
FreshNSoft
Oct 13, 2015 02:52 PM
Rick Wampler
Oct 12, 2015 04:42 PM
dj tes
Oct 7, 2015 04:18 PM
