97 Nissan Maxima leaking sunroof
Old Dec 16, 2015 | 10:38 PM
Bluz's Avatar
Hello everyone!
I've had my maxima since 2009 and I never used the sunroof because the motor was going out. Well, the other day I bumped the button for it and then, like an idiot, I decided to wash the car. I didn't even think about the sunroof opening some until the water started dripping. Blah! I took it to my mechanic and he said it is shot...he thought he got it closed but after 2 days of heavy rain I've got a waterline around the sunroof/headliner. I also have a mucky wet looking area by the tip of the drivers side door in the headliner. I don't have the money or time to start replacing things. I'm wondering if anybody has sealed theirs with silicon or something? I would appreciate any tips or suggestions. I don't need it working I just don't want it to leak. Thanks!
Old Dec 16, 2015 | 10:50 PM
bumpypickle's Avatar
Originally Posted by Bluz
Hello everyone!
NO!!, do not seal it up. If I can recall correctly, there is a way to shut it manually. Search or wait for members to chime in. I will look in my Haynes manual and see if there's any info I can give you
Old Dec 17, 2015 | 12:04 AM
Bluz's Avatar
Ok...yea I'll wait for others to chime in. It's never leaked before...at least not bad enough to show on the headliner. My floorboards aren't getting wet though so maybe some of the drains are working. I'm afraid to open it to clean the drains because the motor is going out and I'm not sure I'll get it closed.
Old Dec 17, 2015 | 01:52 AM
Okay so apparently if you take off a plastic panel near or on the sunroof switches, there is a manual override. You will need a larger hex bit. If it doesn't come down or slide back then you will need to rebuild it with a rebuild kit that should cost less than $50
Old Dec 17, 2015 | 03:59 AM
Well hopefully you can use the screw method I'd not, here's a link for the sunroof servicing: http://www.vqpower.com/v3/content/sunroof-service-procedure
Old Dec 17, 2015 | 09:08 PM
Bluz's Avatar
Thank you! I'll see what I can do with it...
Old Dec 18, 2015 | 12:27 AM
I've also read one members thread that said he forced it shut. Not a good idea but if you were to do this temporarily until you swapped in another youd be in the clear. I hope I don't run into this problem...
Old Dec 18, 2015 | 11:00 AM
JoshG's Avatar
I never touch the sunroof anymore, If I want to use the sunroof I just open up the cover to see the window view.. last time It worked perfectly but I don't want that one moment where it just stops working when its open.
Old Dec 18, 2015 | 11:17 AM
I only really use the feature that makes it slightly pop up. It's nice having a window to exhaust hot air in the winter to make cabin Temps just right. I never really slide it back though. Mine seems to be in good condition, but I'm sure it wears more sliding than popping up
Old Dec 18, 2015 | 09:30 PM
lux97Max's Avatar
The sunroof can be adjusted. Theres a cover on each side with i believe with either 2 10mm or 12mm bolts. Loosen them up and adjust as needed.
Old Dec 19, 2015 | 09:26 PM
Bluz's Avatar
Thanks for the responses! i haven't gotten around to messing with it yet...luckily it hasn't rained!! lux97Max, where do you mean? Mine actually looks like it is tipped up a bit in the back and the front is a little lower than the roof. bumpypickle, how do I pop that cover off so I can try to manually close it? Thanks!
titanfire_5
Dec 16, 2023 10:53 PM
jonreidhead
Jan 6, 2016 09:38 AM
charliec
Oct 19, 2015 07:11 AM
Mattx
Forced Induction
Oct 17, 2015 11:59 PM
