metal-on-metal grinding noise when turning left
Old Dec 25, 2015 | 07:14 AM
carguy96's Avatar
Whenever I am driving and I turn left, the car makes this bizarre sound that sounds like metal is grinding on metal. Imagine if somebody took a cowbell and threw it like a football and you heard the cowbell ringing very fast. That's what it sounds like (weird analogy, but best way I can describe it). Could it be a CV joint? Thanks.
Old Dec 25, 2015 | 08:35 AM
Quickywd01's Avatar
Brake rotor shield is bent inwards touching rotor upon hard cornering. Stick hand in wheel gaps or behind and bend shield back and away from the rotor a little using your palms is best. Good luck.
Old Dec 25, 2015 | 04:38 PM
carguy96's Avatar
This may sound stupid, but do i need to take the wheel off to get to it, or the brakes? Also, how will I know what the brake rotor shield looks like?
Old Dec 25, 2015 | 06:35 PM
pjgreek's Avatar
The shield is just sheet metal next to the rotor, you don't need to take the wheel off to get to it.
Old Dec 25, 2015 | 08:04 PM
carguy96's Avatar
Cool, is there any sort of picture of this just so I have a better idea of where to look?
Old Dec 26, 2015 | 03:24 AM
bumpypickle's Avatar
It is a thin round piece of metal that surrounds your rotor. You cannot mistake it for anything else.
Old Dec 26, 2015 | 03:25 PM
pjgreek's Avatar
What pickle said, it's on the inboard side of the rotor and surrounds most of it, except for where the caliper is. Google "rotor shield" for images and when you crawl under your car, you'll see it.
Old Dec 26, 2015 | 06:26 PM
asand1's Avatar
Could be a shield, a CV joint, or a wheel bearing. Has anyone been under the car recenly, or have you hit debris in the road? Does the noise come from the right side when turning left?
T0neyDanza
Feb 3, 2016 08:51 PM
Derrick2k2SE
Dec 30, 2015 11:45 AM
Dab
Dec 25, 2015 02:11 PM
solariis
Dec 22, 2015 08:12 AM
2kmist
Dec 15, 2015 05:13 PM
