Obd system monitors question
Old Jan 7, 2016 | 03:18 PM
bumpypickle's Avatar
How long does it usually take for the emissions monitors to ready up? I have a few codes I cleared to pass inspection and figured a 15 minute drive would be long enough but the evap, egr, cat, and oxy sensor systems aren't ready yet. These DTC's don't usually pop back up for at least a week so I'm thinking drive it for like 2 days and they should be ready?
Old Jan 7, 2016 | 03:50 PM
JvG's Avatar
JvG
I have driven the car for a week or more, and still did not have the codes totally ready for emissions testing.
There is a procedure which nissan published which shows how to drive the car so that the codes clear as rapidly as possible.
Might be in the stickies. Or perhaps another member will tell you how to find it.
Old Jul 1, 2016 | 02:17 AM
Jeremiah Zampetti's Avatar
My smog guy told me to climb to 65mph then let it drop without using the brakes back to 10mph and do that 2 or 3 times.
Old Jul 1, 2016 | 04:52 AM
This thread is 6 months old, I figured out the drive cycle through searching but took too long so I just went a diffeet route to beat emissions
Old Jul 1, 2016 | 09:54 AM
I know it's old but I though I'd put it out there. Maybe one day sombody will need it in a pinch.
Old Jul 1, 2016 | 06:35 PM
slowmanvns's Avatar
A mechanic told me to drive about 60 miles immediately after he cleared the codes and not to turn off the car during this time.....only probably because the same day I needed my inspection done.
Old Jul 2, 2016 | 10:17 AM
maximaxi's Avatar
Two monitors can be not ready and you can still pass
Old Jul 2, 2016 | 11:09 AM
Well it's really alot more involved than just driving 60 miles. There is a certain sequence of driving conditions you must put your car through to the monitors.
The sequence for 96-97 models is located here: http://lyberty.com/car/Maxima_A32_docs/NTB98-018c.pdf
Old Jul 3, 2016 | 11:22 AM
maxorgy's Avatar
Will the driving pattern also apply for a 96' Infiniti i30 since it shares the same engine as the Maxima?
Old Jul 3, 2016 | 11:33 AM
seeing as how the i30 is identical mechanically in every component I would say yes it should work.
jlee8569
Sep 19, 2016 03:31 PM
FlaMark
18
Feb 10, 2016 05:57 AM
GregL65
Jan 20, 2016 01:59 PM
bthornton83
Jan 9, 2016 03:09 PM
bvb_09
Jan 5, 2016 07:22 PM
