Help me identify possible issues 98 max
Old Jan 9, 2016 | 03:34 PM
signewton's Avatar
My car crapped out on me while driving. My mechanic put an alternator in and after about a week, the car crapped out again. If I get a boost, the car will last for about 30mins and then it will die. When ever I put the key in the ignition to turn on the car, the car gives off a rapid clicking sound.
other issues I found using the computer check thingy
-error code: cylinder 6 misfire
-error code: Exhaust gas recirculation control solenoid valve
-whenever I press the gas pedal all the way down, it sometimes get stuck and I have to unstick it, crazy stuff.
-the battery has some nasty looking stuff on it, based off my readings here that can also contribute to my car not being able to start.
I would like to buy as many of the parts I need as possible that way my mechanic can just worry about installation. How much am I looking to pay to have this stuff fixed. I have zero car knowledge.
Old Jan 9, 2016 | 04:44 PM
vqmaxman's Avatar
Clean battery terminal check battery volts with car running if neg volts replace battery also since you replaced the alternator. Check injector on 6 and cylinder 6 coil. The egr needs to be cleaned and get a new egr Solenoid valve.
Old Jan 9, 2016 | 07:08 PM
signewton's Avatar
i also forgot to mention that when ever I come to a complete stop then attempt to go again- The car pauses for like 2 seconds then takes off like a rocket
ProfitSee
Dec 5, 2015 05:44 PM
Queenstmax90
Dec 3, 2015 03:10 PM
Mishift
Nov 1, 2015 03:55 PM
dj tes
Oct 28, 2015 08:46 AM
mikeg75
Oct 24, 2015 11:37 AM
