Speedometer not working
Old Feb 29, 2016 | 07:23 PM
blkmax1's Avatar
I
recently bought a 97 se auto... The speedometer doesn't work and it needs a little work. What are some things I should replace before the summer. The car had been sitting since July of last year. This is her after a good clean up and engine bay cleaned
Old Feb 29, 2016 | 09:49 PM
DennisMik's Avatar
The speedometer is driven by the VSS in the transmission (Vehicle Speed Sensor).
Change the oil and filter right away, like yesterday. You didn't mention the mileage, so it's hard to say exactly. Normal maintenance is the guideline. Brakes, fuel filter, struts and shocks, spark plugs are possibilities. Get the auto trans oil changed, but DO NOT have the transmission flushed.
here is a link to the maintenance schedule. Read this whole section:
http://boredmder.com/FSMs/Nissan/Maxima/1997/MA.pdf
Here is a link to the coplete service manual:
Old Mar 5, 2016 | 10:25 PM
blkmax1's Avatar
The car has 270k... I plan on changing the oil, tune up and brakes. I think its a gold package Maxima. So should I just drain the atf fluid and top it off
Old Mar 6, 2016 | 12:27 AM
DennisMik's Avatar
Gold package is just an appearance thing, no mechanical differences.
Drain the oil out of the transmission and refill. Draining the oil will not drain all the oil, the torque converter does not drain. You will get about half the oil to drain, 4 quarts approx if the trans is full. But by changing half the oil you are adding fresh chemicals that will help the transmission.
Old Mar 8, 2016 | 02:12 AM
blkmax1's Avatar
Thanks will do... So far i seafoamed the motor, added it to the gas, changed fuel filter, new battery, oil and spark plugs. What else should I do on a budget
Old Mar 8, 2016 | 03:24 AM
Daniel VQ30life's Avatar
How's the air filter? Any codes?
Old Mar 10, 2016 | 03:08 AM
blkmax1's Avatar
I did all of that... Yes I have a check engine light...Haven't read the codes yet...
Old Mar 10, 2016 | 03:09 AM
blkmax1's Avatar
Speedometer is working!
reallywildstuff
Mar 2, 2016 02:36 PM
FishermanDude
Feb 29, 2016 03:22 PM
slickblack94
Feb 29, 2016 10:33 AM
