2 Questions
Old Jan 29, 2002 | 03:51 PM
MaXXXXeD Out's Avatar
2 Questions
Hey All,
2 quick questions:
1- When making the turn signal / side marker mod, you cut the ground from the side marker and splice it to the positive of the turn signal, correct?
2- Is the Nissan emblem on the front grill attached like the ones on the trunk, or is it held by screws?
Thanks!!
Old Jan 29, 2002 | 04:00 PM
Bags's Avatar
VG Ridah's Biatch Hoe
1 Remove the Blinker and side lights from the car.
2 CUT the ground from the sidemarker and reroute it so you can splice it to the (+) of the turn signal. If you don't cut it, all the current from the (+) of the turn signal will go to the uncut ground of the sidemarker = short circuit = blown fuse...
3 Test: when lights are off: Blinkers should go on at same time
when lights are on: Blinkers whould alternate when flashing.
4 Replace lights, and repeat on other side.
you only get 1 answer from me
Old Jan 29, 2002 | 04:34 PM
max808's Avatar
The hamburger is stuck on by adhesive, not screws.
Old Jan 29, 2002 | 04:49 PM
Thanks all!!
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
