Upper radiator hose
Old Jun 1, 2016 | 11:08 AM
ShunDoe's Avatar
Upper radiator hose
My upper radiator hose is expanding/Boulding out. Is that because the hose is old and I need to replace it or is that a internal problem?
Old Jun 1, 2016 | 11:44 AM
bumpypickle's Avatar
It's just old. You'll need to drain the rad to change it out. I would flush the rad and change out the lower hose as well as put new clamps on. Very easy job.
Old Jun 1, 2016 | 01:48 PM
JvG's Avatar
JvG
your hose will blow this summer unless you replace it like right now. Usually the top radiator hose is the first to go. You might as well replace the bottom hose while you are in there anyway. Might as well spray the radiator with a hose to remove bugs and filth which could block air flow.
Old Jun 1, 2016 | 07:05 PM
ShunDoe's Avatar
It's actually a need radiator I just couldn't afford to replace the hoses at the time but I stopped by Autozone. I will install it tomorrow. Thanks
Old Jun 1, 2016 | 07:13 PM
ShunDoe's Avatar
Yea i stopped by autozone and got a hose. I normally spray the radiator down with a pressure washer when I go to wash my car. But I will be replacing the lower hose soon. Thanks for the advice
Old Jun 1, 2016 | 11:10 PM
JvG's Avatar
JvG
Have you replaced the radiator yet, or not. I don't quite understand what you mean
Old Jun 2, 2016 | 06:32 AM
ShunDoe's Avatar
Yes I replaced the radiator . I just never replaced the hoses
eastsidemoon
Jun 23, 2016 09:01 PM
brandon9686
Jun 4, 2016 09:28 AM
Boston003
Jun 2, 2016 09:44 AM
