2002 maxima bose sub replacement
Old May 31, 2016 | 04:37 PM
brandon9686's Avatar
I have a 2002 maxima.with bose speaker system and tge sub in the back is blown (no good) is there a way I can replacement this with an after market sub. If so how would I go about doing this.
Old May 31, 2016 | 06:36 PM
Derrick2k2SE's Avatar
Is it actually blown (cracking and distorted) or just not playing at all?
Old May 31, 2016 | 06:41 PM
It is vibrating and cuts out sometimes it is the speaker vibrating I checked
Old May 31, 2016 | 06:53 PM
In that case it's probably not the relay. Many of us have had to replace, bypass or resolder one relay near the sub that causes intermittent, and eventually permanent, cutout.
There are others here with a lot more stereo knowledge than I have. Hopefully they'll help.
Old May 31, 2016 | 08:53 PM
96SEmaxB's Avatar
I just folded up cardboard and superglued it to the relay in the sub amp so it presses up on the housing, been working great ever since
Old Jun 1, 2016 | 06:07 AM
Prophecy99's Avatar
i bought new relay and soldered in, now its bumping !!!!
Old Jun 2, 2016 | 03:20 PM
I tried putting card board where the speaker housing is and it still vibrates a little but it slunds muffled just want to know if anyone knows if you can replace the speaker with an aftermarket one because I cant find any stock ones
Old Jun 3, 2016 | 03:35 AM
Prophecy99's Avatar
fix it for 30 mins and 7$ ?
Old Jun 3, 2016 | 09:12 PM
DennisMik's Avatar
Bose speakers are not compatible with aftermarket speakers. Aftermarket speakers are 4 ohm and Bose speakers are 1 ohm. If you put in an aftermarket speaker in a Bose system, you won't hear anything.
Old Jun 4, 2016 | 08:05 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Oh, cmon, now. That's absurd and not how electricity works. It will have a fraction of the power, but it will still work. I had 12s hooked up to the stock blose sub wires. I had very efficient boxes (home made ftw). Granted, in parallel, they were 2 ohms, but even that ****ty little amp could make them pound hard in comparison to the stock speaker. A more efficient speaker that's also dual voice coil would work better than stock (doubt free air subs are common, though). Stock is pure garbage, though. Free air...wtf were these ******** thinking (cheap skate ****s).
Plenty of speakers in the junkyard, OP.
Old Jun 4, 2016 | 08:19 AM
Is there a speaker that you know of that will mount in place of the stock bose sub that I can just replace it thats what im looking for. I kinda want to aviod junkyards because they may be no good also but if thats the only option I will just have to go to the junkyard
Old Jun 4, 2016 | 09:28 AM
Bad *** Newb
Nope, never looked into it. It really is pointless. Replace head unit and get a real sub is the route you go if you replace anything with non-stock.
The actual speaker failing should be rare. If the solder joint is bad on the junkyard one, then you can either fix it or splice in the electronics part from yours.
bbsitum
Sep 6, 2016 04:32 PM
District
34
May 19, 2016 10:54 AM
Maximusdriver
Apr 20, 2016 11:50 AM
Nick0360
Apr 4, 2016 06:42 PM
MAXUSED04
Mar 20, 2016 03:43 PM
