change transmition oil on 98 automatic
Help!!!! My 98 GXE have 30000 miles on it and I want to do my first transmition oil change, is it is as easy as changing engine oil, just drain and refill????? My one is automatic, do I need to remove the "pan" ??? If it is easy , should I use synthetic transmition oil??
I just do not feel paying $50 to the dealer if it is only "drain and refill".
Any help will be appreciate..
Re: change transmition oil on 98 automatic
BUT your owners manual is a good tool to have. If you do not have one.. get one.. or a Factory Service manual or chilton/haynes manual
Originally posted by redmaxpa007
i checked mine at 30k.. it was fine.. i checked it at 60k.. it was ready to be changed....
And it's been lab proven that 30k is the maximum interval for Nissan ATF.....you probably took tens of thousands of miles off the transmission's life waiting until 60k.....
Bill,
Don't you know most people here would rather spend money on lighted windshield washer nozzles than preventive maintenance? If it doesn't say you have to do it in the manual, they won't. It doesn't matter that Nissan, and other makers, don't care what happens to the car after 100k miles. How many people to you think have changed their brake fluid?
Originally posted by bill99gxe
Did anyone think to look at the Oil/ATF analysis spreadsheet thread at the top where recommendations for this question are addressed....
Originally posted by brubenstein
Bill,
Bill,
We have brake fluid in our cars?
Yes, unfortunately I know........
i meant to say i checked it at 15k and changed it at 30k.. not what i said...
you are correct bill... that would kill the already weak link in the car.......
I change mine every 5,000 miles regardless (DRAIN/REFILL)! Once a year i will clean the pan, replace the gasket, drain plug, and screen filter. Also i flush out the system once a year as well. I use Amsoil ATF Synthetic fluid. I don't have time to be frugal with a vehicle, if appropiately cared for will carry you for several hundreds of thousands of miles! 96se 161,500 miles, excellent shifts, I literally feather my gas pedal! Oh and draining is as easy as an oil change. Go to Walmart and pick up a 15 qt basin. Just drive it, but don't beat the Sh*T out of it. Even if you are late and just changing it at 60,000 you should be o.k. granted you did not beat the **** out of it. Good Luck!
RWCreative
Sep 21, 2015 11:01 AM
97_GXE
20
Sep 17, 2015 08:12 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
