motor and tranni out of 01 into my 96, easy swap?
Old Sep 29, 2016 | 11:56 AM
Nickie Watts's Avatar
I have a donor car, so everything I need should be there, the problem is my 96 has a burnt valve, I found a wrecked 01 I would like to get the transmission and the engine out of to put in my 96.
What all would I need to change over? I am hoping the block is the same, I know the intakes are different and have read a little about the cam being more aggressive but that is all I can find.
I will be buying the wrecked car so if anyone knows what all I will have to swap in order to get everything to work, please let me know.
Old Sep 30, 2016 | 04:35 AM
luke95gxe's Avatar
What transmission do you have auto or five speed? If its auto the trans will require finess to work. As far as the engine goes its a direct drop in the only real difference is intake and fuel. You can use the intake and injectors its what we like to call a 00vi swap. Ypu will need the fuel injecor pig taisl from the donner engine harness. To answer your question yes u can swap
discobiscuit
Aug 10, 2016 12:35 PM
MaximaNoob1
Aug 2, 2016 04:15 PM
Ike83
Jul 26, 2016 07:06 AM
bph1994
Jul 24, 2016 07:58 PM
