Orange/pink corrosion on top of radiator
Old Dec 7, 2016 | 03:11 PM
maximaxi's Avatar
Is this just a bad radiator, or did something else cause it? The engine is not overheating, and the coolant level is acceptable.
Old Dec 7, 2016 | 03:51 PM
maxima297's Avatar
Looks like it's time for a new radiator.
Old Dec 8, 2016 | 02:36 AM
max ride 41's Avatar
that hood release cable should be replaced as well. thought you had a stick under the hood at first.
Old Dec 8, 2016 | 04:24 AM
Turbobink's Avatar
OMFG ... +1 on that.
I suppose I should be thanking the gods that I live in FL.
... lack of corrosion and all.
Old Dec 8, 2016 | 05:31 AM
CS_AR's Avatar
Looks great Turbobink! It always does. You've got to tell us about the cable conduit and coupling that runs on top of the VC. I see you are using Nissan OEM hose clamps.
Those clamps are so easy to use. Just put them into position, then release clip and you're done.
Old Dec 8, 2016 | 06:21 AM
M in KC's Avatar
Ya what's up with the extra wiring do-dad Turbobink.? You are in CS AR's league for engine bay cleanliness.
Old Dec 8, 2016 | 06:48 AM
CS_AR's Avatar
He keeps his like that. The inside of his engine looks like that too. Mine are a carbon and corroded up mess when I get them.
Old Dec 8, 2016 | 07:18 AM
CS_AR's Avatar
Since Maximaxi is not loosing coolant, I think there is time to plan and shop around for a new radiator, hoses, clamps and other items needed to keep a cooling problem at bay.
Old Dec 8, 2016 | 10:45 AM
Turbobink's Avatar
Grounding kit ... I just covered the assemblies with wire loom and routed things a little different.
https://maxima.org/forums/4th-genera...5-shipped.html
