AirBag Light After AirBag Deployment
Old Dec 10, 2016 | 03:22 AM
jdreid13's Avatar
Can you simply use the reset method (Door Switch 7 Second Reset Method) to clear the hard code off of the airbag module after being involved in a collision? I'm just wondering before I go ahead and try to install my new set of airbags in.
Old Dec 10, 2016 | 06:54 AM
CS_AR's Avatar
The code will not reset until the deployed bag has been replaced. Most often, you will need to replace the SRS control unit that is under the center console. I had to replace my control unit after an air bag deployment to clear the code.
Always disconnect the battery when working with the SRS.
Here's a thread about my air bag deployment and replacement.
Did you have a seat bag deployment or just steering and dash?
Did the seat belts deploy the explosive charge? Do the seat belts retract like they did before the accident?
https://maxima.org/forums/4th-genera...-question.html
Old Dec 10, 2016 | 10:08 AM
Old Dec 10, 2016 | 01:43 PM
jdreid13's Avatar
Thanks man! Appreciate the info!
Old Dec 11, 2016 | 06:03 PM
jdreid13's Avatar
No, just my steering wheel airbag and my dash deployed. I own a 95 Maxima. Would it be safe to reinstall a new set of airbags before replacing the airbag sensor unit? Because I just don't want them to deploy since it already has an error code on my current airbag sensor.
Old Dec 11, 2016 | 06:16 PM
CS_AR's Avatar
I did that in a round about way. I didn't realize that I needed to replace the SRSCU until after I replaced the bags and couldn't get the code to clear and the light to go out.
Old Dec 11, 2016 | 08:24 PM
jdreid13's Avatar
Can you use an OBD2 to remove an airbag error code? Or is a possibility it can appear again, and be worthless?
Old Dec 12, 2016 | 01:07 AM
CS_AR's Avatar
Nope. 4th gens have very basic ODB2 functionality. It takes NDS1 software that uses the 14 pin Nissan Consult port to reset air bag codes. The Consult port is located behind the fuse panel box.
