Rough idle. So i done a service in my 98 2.0 v6 maxima.
Old Dec 23, 2016 | 10:45 AM
Marco Garcia's Avatar
So i changed plugs. air oil and fuel filter. engin oil transmission oil. fan belt. and then the problems started iddling very eratic when driving 1.2.3 gears at 2000rpm the car jerks after reading up on things i have not done the follwing
new coils
new throttle sensor
new pipes from tappit cover to air intake box.
clean throttle valve
cleant throttle.
cleaned mass airflow sensor
nothing has solved this problem is there anybody that can help me
Old Dec 23, 2016 | 12:02 PM
Rit's Avatar
Rit
Marco
What brand, type and model number plugs did you install ? These engine run best on NGK Iradiums. Any other kid may cause your problem. Did you check the gap of the plugs before installing ? Don't assume that they are pre-gapped correctly from the factory. When you removed the old plugs, and installed the new ones, were you careful with removing the coil-packs ?
Was it running good before installing the plugs ? If not, then it is likely a bad coil pack.
Are you setting any MIL codes ? If so, read the code, and it will point to your problem.
I would concentrate on the plugs. I doubt if anything get affected by the other things that you did.
Good luck.
Old Dec 23, 2016 | 01:29 PM
maxima297's Avatar
NGK Platinums are the OEM spec ones. Also, are you using OEM coil packs? Our cars are EXTREMELY fussy when it comes to sensors and if it's not OEM, the car will protest until that changes.
Old Dec 24, 2016 | 08:00 AM
edwardh1's Avatar
my maxima throws a code on napa chinese coils, mechanic replaced with oem runs fine now last 4 years
