is it possible that no ECU ?
Old Jan 15, 2017 | 04:52 AM
mashav's Avatar
hi,
I followed the check engine light manual and did everything as written but after I removed the plastic cover and tried to turn the screw head I noticed that there is no screw there! is it possible?
attached pics
Old Jan 15, 2017 | 06:34 AM
lux97Max's Avatar
That is highly unlikely unless somebody screwed up lol. Do You have have a 95?
Old Jan 15, 2017 | 07:22 AM
mashav's Avatar
98 and there was plastic cover from factory..
Old Jan 15, 2017 | 10:02 AM
DennisMik's Avatar
The screw has been known to break off of the printed circuit board from being turned against the stop with too much force.
The fact that the tape is still over the hole means nothing, I was always careful to not destroy it and then re-cover the hole.
Old Jan 15, 2017 | 10:24 PM
mashav's Avatar
is it ECU at all ? Its on the right side of pedals but doesn't look like the image in: http://vbxmaxima.8m.com/ecu.html (missing hole)
Old Jan 16, 2017 | 02:17 PM
DennisMik's Avatar
The photo that you posted looks (crappy quality) looks like the ECU to me, it is just missing the decal/label that covers the adjustment hole.
Old Jan 17, 2017 | 08:45 AM
^My thoughts exactly.
Old Jan 17, 2017 | 12:32 PM
JvG's Avatar
JvG
It's possible that someone broke the screw head off in the past.
Buy a code reader. They cost as little as 15 bucks on amazon.
The code reader will do all of what the screw does, and more.
Old Mar 4, 2018 | 06:29 AM
Shannon and Ian's Avatar
Does the code reader reset the ECU even after the screw has broken?
Old Mar 4, 2018 | 08:03 AM
CS_AR's Avatar
I would say yes. I haven't seen a reader that could not reset codes. Though anything is possible. The cheap ones at Walmart reset codes.
