Need help !!!
Old Jan 15, 2017 | 12:32 PM
Alblount1986's Avatar
Need help !!!
I took off and cleaned my Throttle body and IAC Valve. When i put it back together i can only get it to 2000 RPMS in each gear and it wont go any higher. I have my petal to the floor and no response. Plus it sounds like its leaking air from somewhere. I need help PLEASE !!!
Old Jan 15, 2017 | 12:38 PM
lux97Max's Avatar
Did you use a new gasket? and did you use proper tightening sequence? Not that it really matters but Sounds like you got a leak some where. Check and Make sure you plugged in the 3 plugs on the iacv. I bet its a simple fix.
Old Jan 15, 2017 | 01:07 PM
peb396's Avatar
Another thing to look for is vacuum lines. You might have disconnected one or even broke an already weakened one. What did you clean the TB with?
Did you allow it to dry?
I am with lux97...bet it is something simple that a few minutes away will help you see.
Old Jan 15, 2017 | 01:30 PM
I used Carb. & Choke Cleaner
Old Jan 15, 2017 | 01:31 PM
Original gasket still
Old Jan 15, 2017 | 01:46 PM
I accidentally adjusted the screw on the IAC Plug and I don't know if that has anything to do with it
Old Jan 15, 2017 | 02:14 PM
Rit's Avatar
Rit
Any Check Engine Light ?
Old Jan 15, 2017 | 03:31 PM
max ride 41's Avatar
something wasn't connected/adjusted properly when you put it back together, try to re-trace your steps and see if maybe you left a hose off or didn't tighten down the throttle body tight enough.
Old Jan 15, 2017 | 05:00 PM
yes i an o2 sensor, IAC Valve, and speedometer codes, Im going to go back and retrace my steps tomorrow. I will keep posted
Old Jan 15, 2017 | 06:25 PM
Now why did you go and do that? Of course that matters. Reset it per the FSM in my signature.
Did you monkey with the MAF at all?
Old Jan 21, 2017 | 12:41 AM
i only used MAF cleaner. It hesitates really bad while accelerating and when it gets to 2000 RPMs its like the acceleration just stop. and now im smelling gas a little bit
Old Jan 22, 2017 | 02:53 PM
I took everything off and put it back together and made sure all the hoses are on correctly but its still doing the same thing. It wont go rev past 2000 RPMs. The guy at Orileys said that i might be getting too much air. Is this possible ? I really need help !!!
Old Jan 22, 2017 | 03:33 PM
did you scan for codes? sounds like your in limp mode.
Old Jan 24, 2017 | 06:40 PM
No. How would i get it out of limp mode ?
Old Jan 24, 2017 | 08:16 PM
we have the interwebs, search is your friend
https://www.google.com/webhp?sourcei...t+of+limp+mode
Old Jan 25, 2017 | 02:58 AM
bumpypickle's Avatar
I find it strikingly ignorant that you can tell a new registered user, that obviously doesn't know much about the 4G maxima, to search yet you (member since 06)
post a thread (https://maxima.org/forums/4th-genera...ths-p0300.html) questioning how to
handle a simple egr code which we all know has been thoroughly discussed over and over again.
Old Jan 25, 2017 | 07:05 AM
0406 is not a common code, i've never seen that or seen it discussed in these boards. what i found out ( through searching on the interwebs ) is that it's egr related but that it could be a multitude of problems and my thread was started in the hopes that someone had or has had the same code and might have an answer to my problem. i didn't just start a thread that simply say's, " need help ", i was emphasizing the fact that he should search my reply a little and not just sit around waiting for a answer which i hope he's done even though i supplied a link to help him anyway.
