acceptable tps voltages.....
i saw that it should be between 4.6 and 5.1??? mine is original ( 22 years old ) and read 4.2, a little on the low side. on it's way out, clean, or replace?? have had a few issues with idle as of late and still have a p 0300 code, thanks
Before you replace the TPS, check that you have 12 volts coming into the sensor. If this is somehow low, a new sensor isn't going to help. Check that the connector doesn't have any corrosion inside it.
