Huge Favor - Take Pics of Your IACV For Me
Old Feb 25, 2017 | 09:33 PM
Violator's Avatar
Long embarrassing story short, while removing UIM had a slip and broke some of the plastic on the tan part of the IACV. No junkyards around have maximas and I'd like to save the $50 and salvage this. Before I go JB welding it back together I want to make sure I have all the connections aligned how they were and none got bent out of place.
so if someone could remove theirs to take a cpl good pictures at the right angle so I can use it as a guide, it's the tan piece held on by 3screws and I'd be extremely grateful
in the last pic the pin on the right is bent back a little bit I assume it's supposed to be the same as the others
Old Feb 26, 2017 | 11:05 AM
CS_AR's Avatar
Here you go. There is a spring the drops into the center of the stepper motor.
Old Feb 26, 2017 | 02:48 PM
Violator's Avatar
Thank you so much exactly what i needed. That's what I was missing, when i actually separated mine the black plastic piece and a washer stayed with the rest of the iacv, pulled it out with pliers and lined it up seems like the long 3 prongs on it should be soldered not just touching so i'll solder those and jb weld the plastic and hopefully it will still work. Thanks again
Violator
Feb 25, 2017 10:04 AM
